Hi I want to simulate the code below but can't create a testbench for it. I'm still new to vhdl. Can anyone give me advice on how to simulate it. library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity DataGen is Port ( Input : in STD_LOGIC_VECTOR (1 downto 0); CLK, Reset : in STD_LOGIC; Output : out STD_LOGIC_VECTOR (15 downto 0)); end DataGen; architecture Behavioral of DataGen is signal counter : STD_LOGIC_VECTOR (1 downto 0); begin process ( Reset, CLK ) begin if Reset = '1' then -- If the reset button is pressed it clears Counter <= "00"; -- the Counter value and sets it to 00 elsif CLK'event and CLK = '1' then -- Used for Mode 1,2,3; Increments the value of Counter Counter <= counter + '1'; -- each time the CLK singal is 1 therefore creating an endless if Counter = "11" then -- loop for Counter else counter <= "00"; end if; end if; end process; process ( Input, CLK, Reset, Counter ) begin if Reset = '1' then -- Resets the 7-segment display if Reset is 1 Output <= X"0000"; elsif CLK'event and CLK = '1' then --Mode 0 if Input = "00" then --if selected it will display A5A5 Output <= X"A5A5"; --Mode 1 elsif Input = "01" then -- if selected will display 1 to F continously case Counter is when "00" => Output <= X"0123"; when "01" => Output <= X"4567"; when "10" => Output <= X"89AB"; when "11" => Output <= X"CDEF"; when others => Output <= X"0000"; end case; -- Mode 2 elsif Input = "10" then --if selected will display 500662 continously case Counter is when "00" => Output <= X"5006"; when "01" => Output <= X"6250"; when "10" => Output <= X"0662"; when "11" => Output <= X"5006"; when others => Output <=X"0000"; end case; -- Mode 3 elsif Input = "11" then --if selected will display 503188 continously case Counter is when "00" => Output <= X"5031"; when "01" => Output <= X"8850"; when "10" => Output <= X"3188"; when "11" => Output <= X"5031"; when others => Output <= X"0000"; end case; end if; end if; end process; end Behavioral;
a forum will help you to solve particular issues, not general working principal better get a book for basic knowledge or study it at university
this could be your code nd if you are very new to this field then force values directly in wave form and check results library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity DataGen is Port ( Input : in STD_LOGIC_VECTOR (1 downto 0); CLK, Reset : in STD_LOGIC; Output : out STD_LOGIC_VECTOR (15 downto 0)); end DataGen; architecture Behavioral of DataGen is signal counter : STD_LOGIC_VECTOR (1 downto 0); begin process ( Reset, CLK ) begin if Reset = '1' then -- If the reset button is pressed it clears Counter <= "00"; -- the Counter value and sets it to 00 elsif CLK'event and CLK = '1' then -- Used for Mode 1,2,3; Increments the value of Counter Counter <= counter + '1'; -- each time the CLK singal is 1 therefore creating an endless if Counter = "11" then -- loop for Counter counter <= "00"; end if; end if; end process; process ( Input, CLK, Reset, Counter ) begin if Reset = '1' then -- Resets the 7-segment display if Reset is 1 Output <= X"0000"; elsif CLK'event and CLK = '1' then --Mode 0 if Input = "00" then --if selected it will display A5A5 Output <= X"A5A5"; --Mode 1 elsif Input = "01" then -- if selected will display 1 to F continously case Counter is when "00" => Output <= X"0123"; when "01" => Output <= X"4567"; when "10" => Output <= X"89AB"; when "11" => Output <= X"CDEF"; when others => Output <= X"0000"; end case; -- Mode 2 elsif Input = "10" then --if selected will display 500662 continously case Counter is when "00" => Output <= X"5006"; when "01" => Output <= X"6250"; when "10" => Output <= X"0662"; when "11" => Output <= X"5006"; when others => Output <=X"0000"; end case; -- Mode 3 elsif Input = "11" then --if selected will display 503188 continously case Counter is when "00" => Output <= X"5031"; when "01" => Output <= X"8850"; when "10" => Output <= X"3188"; when "11" => Output <= X"5031"; when others => Output <= X"0000"; end case; end if; end if; end process; end Behavioral;
Hi, it is not best practice to merge actual logic with your testbench stimuli. You have to use a separate entity/architecture (essentially an entity without an interface) to exercise your circuit. Let me know if you need further help. Best regards Nikolaos Kavvadias http://www.nkavvadias.com
Small optimization, please use use IEEE.mumeric_std.ALL; instead of use IEEE.STD_LOGIC_ARITH.ALL; because different tools can interpret std_logic_arith different. There should be no drawbacks with numeric_std.
