Forum: FPGA, VHDL & Verilog Verilog : Division of 2 numbers (8bit)
Author: Munteanu Vlad (Company: Automatic Control) (popdog22)
1 useful
I have to divide two 8 bit numbers using Verilog(homework). The module I
have to use is this one:
module divider(
output reg[7:0] q,
output reg[7:0] r,
input [7:0] a,b);
endmodule
where a=b*q+r
I am told that I can use SRT, Newton-Raphson or Goldschmidt algorithms
to solve it, but i don't understand how they work...
Any help pls?
: Locked by Moderator
Author: Mirco (Guest)
the Newton-Algo is easy to understand there are also Tutorials on
youtube.
If the Verilog Code dont have to be synthesizable u also could use the
Goldschmidt algo on wikipedia.
Normaly got help if you have a specific Problem with Verilog but i guess
nobody will do your homework.
Author: Hans-werner M. (hanswerner)
Warum ist der Goldschmidt Algorithmus nicht synthetisierbar ? Das konnte
ich dem Wikipedia Artikel jetzt nicht entnehmen. Welche Gründe sprechen
dagegen ?
> dagegen ?
This is an english forum. Please answer in english.
BTW:
Bitte nicht Plenken!
(I'm sorry to say that "Plenken" is up to now not defined within english
language: http://en.wikipedia.org/wiki/Plenken)
i ment that u can take the c implementation without having a lot of work
to do.
Micro, I've studied the algorithms, and now I have the pseudocode of
RADIX-2 Division of 2 numbers in floating point. But I need the
pseudocode in fixed point, and I cand't figure it out. However i put it
in Xilinx, I get scrambled values when to simulate.
I have attached the pseudocode and the verilog code.
Thanks.
Author: Nikolaos Kavvadias (Company: http://www.nkavvadias.com) (nikolaos_k)
your code (apart from certain mistakes) is not synthesizable. The best
approach is to implement it as an ASMD/FSMD (Finite State Machine with
Datapath), what you attempt will not produce meaningful hardware (or any
hardware that is).
You can have a look to exemplary FSMDs, at my website:
http://www.nkavvadias.com/hercules/
I am the sole developer of HercuLeS, a novel high-level synthesis tool.
What you can find on this page is some info on HercuLeS plus some
examples. There is also a FREE download for Windows 7 64-bit and Linux
32-/64-bit but after you are on your own. The FREE version does not
cover floating-point and fixed-point designs, you have to pay a minimal
sum of around 2k EUR per year (including unlimited support) for this.
Let me know if either you or your teacher/mentor is interesting in using
HercuLeS.
Best regards
Nikolaos Kavvadias
This topic is locked and can not be replied to.
