Forum: Analog Circuits Material used in Peltier thermoelectric module shells
von Julian G. (Company: NSW TAFE College Mt Druitt) (my_other_head)
I wish to try out the Farnell/Element14 Multicomp Peltier thermoelectric
modules or similar, in cascade for cooling an LNA block of a sensitive
microwave band receiver.
1. In general, What is the material used for the shells of these
modules, eg MULTICOMP - MCPE-127-10-13 - PELTIER COOLER, 38.1W?
eg.
http://au.element14.com/multicomp/mcpe-127-10-13/peltier-cooler-38-1w/dp/1639751
2. Does anyone have  dielectric constant values for this and similar
products across a range of frequencies, ie {10, 100, 500} MHz, {1, 2, 5,
10} GHz
3. What adhesive should I use to bond these modules together?
Kind regards,
Julian Grodzicky
von Kai K. (klaas)
The surface is made of Al2O3 ceramics, usually. The dielectric constant
should be about 8...10, depending on chemical purity.
Use a bonding material that is recommended for Al2O3 ceramics. And keep
water condensation in mind...
Thank you for your reply, Kai.
\epsilon = 8...10, that's about a 25% variation, at best.
I might see what else is in the name brand Peltier module market, rather
than the Multicomp brand, even though it seems inexpensive. This is
element 14's/Farnell's generic brand, and could be sourced from
anywhere.  The Product page say these current units come from Russia, so
I'm not sure how product specification variation plays across production
runs, or what the quality of the shell ceramic will be.
