Forum: Analog Circuits Simple audio signal detector
Author: Flok3r (Guest)
my first post here, I hope it fits in this forum.
I just want a device, that detects, if there is a signal (playing audio)
on the incoming audio source AND lets the signal pass to an output audio
jack. So the signal must not be screwed up by the detector part.
I built this using:
-http://www.ti.com/product/lm324
this op amp as inverting amplifier (10meg as feedback, 10k between input
and op amp).
The op amp is single supplied with 5v and "stretches" the signal to
0-5v.
-atmega168/328 (prototyping on arduino)
to measure the amplified signal on the analog pin (simple algorithm
detects audio).
Readout every 2 ms.
-4066 ic
to let the signal pass or not
So far, this works perfect, when using normal audio sources..
When connecting my Smartphone/Laptop/Pc directly from the devices audio
jack the arduino shows fluctuating values (while playing music..), app.
0-4v.
BUT the big issue is when using a usb sound card as audio source.
When connecting these the arduino measures 0v all the time. Only on the
highest volume some "peaks" show up.
I tried different resistor values and other things, always 0v.
There has to some fundamental difference between "normal" audio devices
and usb sound cards I don't get.. Why does this happen/what did I
misunderstand?
requirements:
-5v single supply
-reliable detection, even on low volume/small signals
I am using these usb sound cards:
http://www.amazon.com/Channel-External-Sound-Audio...
http://www.amazon.de/gp/product/B0028RZ23I/ref=s9_...
Author: lutz.h (Guest)
Can you try the microphone input of the sound card to use as a
Oscilloscope
and measure differences between IPOD and sound card.
like Soundcard scope 1.41
Author: HildeK (Guest)
> and op amp).
I am missing a capacitor at the input. There may be a DC offset in one
of your sources.
To which voltage ist the non-inverting input connected?
And: you have a single supply circuit and an inverting amplifier. If you
have a positive input then the output would like to go into negative
regions: not possible. On the other side, an input signal below the GND
pin is not allowed!
So, I wonder why you report of some success.
I measured both on medium volume. Playing the same song on my iPhone and
my Laptop (playing through the Creative Soundcard) gives pretty much the
same gaph (set triggering to off..).
Amlpitude of the iPhone signal is about 200mV
The one of the usb Soundcard (on medium system volume) is 300 mV.
No big differences at all, that confuses me even more :(
but thanks for the hint, great software!
Tried filtering the dc offset with 1-10 uF, same as before..
> pin is not allowed!
I know this problem, but as I said, on standard players everything works
fine.
I dont know how the op amp is doing that, but it can amplify half of the
signal (dont remember if it is the negative or positive half wave). The
amplified result is quiet distorted and only the half of the signal is
reaches the output, but that would be enough for my needs, when it would
work..
Ah, the signal-gnd is connected to +op-amp. signal-L and signal-R are
connected through 10k to -op-amp. 10 meg from -op-amp to out-op-amp.
