1 | library ieee; |
2 | use ieee.std_logic_1164.all; |
3 | use ieee.std_logic_arith.all; |
4 | use ieee.std_logic_unsigned.all; |
5 | entity SRAM is |
6 | generic(width:integer:=4;depth:integer:=32;addr:integer:=5); |
7 | port(Clock:in std_logic; |
8 | Enable:in std_logic; |
9 | Read:in std_logic; |
10 | Write:in std_logic; |
11 | Read_Addr:in std_logic_vector(addr-1 downto 0); |
12 | Write_Addr: in std_logic_vector(addr-1 downto 0); |
13 | Data_in: in std_logic_vector(width-1 downto 0); |
14 | Data_out: out std_logic_vector(width-1 downto 0)); |
15 | end SRAM; |
16 | |
17 | architecture behav of SRAM is |
18 | type ram_type is array (0 to depth-1) of |
19 | std_logic_vector(width-1 downto 0); |
20 | signal tmp_ram:ram_type; |
21 | begin
22 | process(clock,read) |
23 | begin
24 | if(clock'event and clock='1') then |
25 | if enable='1' then |
26 | if read='1' then |
27 | data_out<=tmp_ram(conv_integer(read_addr)); |
28 | else
29 | data_out<=(data_out'range=>'Z'); |
30 | end if; |
31 | end if; |
32 | end if; |
33 | end process; |
34 | process(clock,write) |
35 | begin
36 | if(clock'event and clock='1') then |
37 | if enable='1' then |
38 | if write='1' then |
39 | tmp_ram(conv_integer(write_addr))<=data_in; |
40 | end if; |
41 | end if; |
42 | end if; |
43 | end process; |
44 | end behav; |
i wrote this to create a 4*32 RAM but when i simulate i get a 4*4 RAM. pls help me to find the error.
