Forum: FPGA, VHDL & Verilog synthesisable vhdl codes
Author: vhdl newbie (Company: none) (pranoy)
hi guys,
first of all i'm new to vhdl
my project is to build a microcontroller.
my project guide said to search about synthesisable vhdl codes.
please help me.
Author: Klappskalli (Guest)
you failed!
What time schedule do you have?
You won't believe it, but in a microcontrollers design there are dumped
many man-years of work. And those guys are professionals, not beginners!
Thats a good idea if you want a real uC running on a FPGA.
> please help me.
Whats your question?
A little hint: start with a blinking LED, then a chasing light, and so
on...
Author: Schlumpf (Guest)
Well, then let´s start with the core of your microcontroller.
http://en.wikipedia.org/wiki/LEON
too complicated?? then..
> on...
Author: TM (Guest)
> on...
Hello,
Yes I think the right way is to start with little things. But a
processor also consists of easy parts.
So first start to learn how to describe:
- Multiplexers
- combinatorial Logic
- An ALU should be possible
- State Machines
At the moment I am writing a simple CPU in VHDL
At the moment it is in process but if you want to you can look ath the
source.
http://www.blog-tm.de/?p=80
guys
first of all it's a 4 bit microcontroller with just 8 basic
instructions(+,-,and,or,xor,...).
I have done some basic programs like MUX,DEMUX,full adder,carry look
ahead adder,decoder,encoder,2's complement,counter
I used modelsim as a simulator.
i also designed a simple alu.
MY QUESTION IS
i wrote the alu with statements like
c=a+b;
can i do like this if i'm to run it on an actual FPGA?
Author: PittyJ (Guest)
>> c=a+b;
Forget variables and use signals, if you work on real hardware.
So I think, you have to restart everything.
> c=a+b;
This is no VHDL statement.
Yes you can use +,-,* without any restrictions. But if you want to
implement a / then you have to start thinking...
BTW: you can read such basic things in almost every new book about "VHDL
for FPGAs".
VHDL is NOT a programming language!
I would say that you have done some basic designs on a FPGA.
library ieee;
    use ieee.std_logic_1164.all;
    use ieee.std_logic_unsigned.all;
    entity alu_ent is
        port(
            x,y:in std_logic_vector(3 downto 0);
            a:in std_logic_vector(2 downto 0);
            z:out std_logic_vector(3 downto 0)
        end alu_ent;
        architecture alu_arch of alu_ent is
        begin
        process(x,y,a)
        begin
            case a is
                when "000"=>z<=x+y;
                when "001"=>z<=x-y;
                when "010"=>z<=not(x);
                when "011"=>z<=x and y;
                when "100"=>z<=x or y;
                when "101"=>z<=x xor y;
                when others=> z<="XXXX";
            end case;
    end process;
    end alu_arch;
can i execute this on an actual FPGA?
Where is the clock?
Author: TM (Guest)
vhdl newbie wrote:
> library ieee;
>     entity alu_ent is
>         port(
>         end alu_ent;
>         begin
>         process(x,y,a)
>         begin
>             case a is
>                 when "000"=>z<=x+y;
>                 when "001"=>z<=x-y;
>             end case;
>     end process;
>     end alu_arch;
Yes you can do this on an actual fpga. But the others statement should
result in a defined state like z<= x+y or z <= "0000"
Scince an alu is combinatorial you do not need a clock here but at some
point in the design.
best regards
Tobias
>                 when "000"=>z<=x+y;
>                 when "001"=>z<=x-y;
Here you should implement any kind of rollover handling (in case of
overflow or underflow)...
No, you cannot.
Because VHDL ist not executed on an FGPA.
VHDL describes hardware.
thank you all. :)
what should i do to get high impedance output?
>>                 when "000"=>z<=x+y;
>>                 when "001"=>z<=x-y;
how can i get the carry?
should i use a 4 bit adder instead of the '+' sign?
(Why) do you need high impedance output?
>>> when "000"=>z<=x+y;
>>>  when "001"=>z<=x-y;
Think a little!
And the add one leading bit to recognize overflow/underflow...
What will you gain if you do so?
Author: FPGA-Professional (Guest)
I guess he needs "dont care" insted of high Z.
  • [vhdl]VHDL code[/vhdl]
