1 | library IEEE;
2 | use IEEE.STD_LOGIC_1164.ALL;
3 | use IEEE.STD_LOGIC_ARITH.ALL;
4 | use IEEE.NUMERIC_STD.ALL;
5 | use STD.TEXTIO.ALL;
6 | library WORK;
7 | use WORK.pkgg.ALL;
8 | entity scrambler is
9 | Port ( e : in STD_LOGIC_VECTOR (29 downto 0);
10 | Sel : in STD_LOGIC_VECTOR (3 downto 0);
11 | s : out STD_LOGIC_VECTOR (29 downto 0));
12 | end scrambler;
13 | architecture Behavioral of scrambler is
14 |
15 | SIGNAL rst_n : std_logic;
16 | SIGNAL clk : std_logic;
17 | SIGNAL dout : std_logic_vector(29 downto 0);
18 |
19 | CONSTANT width : integer := 30;
20 | CONSTANT length : integer := 31; -- length of the register
21 | CONSTANT taps : T_LFSR_TAPS16 := (31, 27, 26, 25, 22, 21, 19, 18, 17, 16, 10, 7, 6, 5, 3, 2);
22 |
23 | component genlfsr
24 | generic (
25 | width : integer := 30;
26 | length : integer := 31;
27 | taps : T_LFSR_TAPS16 := (31, 27, 26, 25, 22, 21, 19, 18, 17, 16, 10, 7, 6, 5, 3, 2)
28 | );
29 |
30 | port (
31 | rst_n : in std_logic;
32 | clk : in std_logic;
33 | dout : out std_logic_vector(29 downto 0)
34 | );
35 | end component;
36 |
37 | bgin
38 |
39 | U1: entity work.genlfsr(behavioral)
40 | generic map (width => width ,length => length ,taps => taps)
41 | port map(rst_n => rst_n ,clk => clk ,dout =>dout);
42 |
43 | process (dout ) is
44 |
45 | begin
46 |
47 | s(29 downto 29-dout'high) <= dout;
48 |
49 | end process;
50 | end Behavioral;
