Forum: Analog Circuits Measuring ambient temperature inside enclosure
Author: jm (Guest)
For you heat transfer and temperature measuring experts:
I'm designing a PCB into this enclosure:
http://media.digikey.com/photos/BUD%20Industries%2...
It will be mounted on a wall so the clear cover is facing the user.  The
environment is similar to residential so no harsh environment.
Standoffs will be screwed into the bosses, and a PCB will be mounted on
those.  There will be various indicators visible through the clear
cover.
The PCB needs a sensor to measure the outside ambient temperature.  The
PCB itself will generate some heat, maybe on the order of 1W max from a
micro, a few relays, etc.  My thought is to drill a matrix of vent holes
holes on the top and bottom for two reasons: 1. allow the electronics to
keep as cool as possible, and 2. hoping the resulting convection pulls
in enough ambient air to flow over a temperature sensor mounted on the
bottom of the PCB.
I was thinking of a TO-92 package temperature sensor, mounted straight
off (perpendicular) the PCB and utilizing the full length of the leads
to get it as far as possible from the PCB.
So, I know this is a complex question and testing is the only way to
know for sure.  Anyone have any experience or have any opinions on this
type of thing?  Specifically, what is the likelihood the sensor will
accurately measure the ambient temperature within a few tenths degrees C
with only convection?
I know the heat producing parts need to be kept away from the sensor
(i.e. on the top) and copper traces conduct heat very well, and the
TO-92 sensor leads conduct heat very well too.
Author: Julian Grodzicky (Company: NSW TAFE College Mt Druitt) (my_other_head)
You could try to model your problem with an US NSF-funded free,
open-source, heat flow modelling application Energy2D at
 http://energy.concord.org/energy2d/
and see if that gives you any answers. It's designed with high-school
students in mind, so it shouldn't be difficult to learn. It's not
claimed to be 100% accurate for convection and radiation problems, but
it might give you some ideas. Explore the website to see if it might be
suitable for you.
Else, build up your circuit and power it up, and then look at it through
an IR camera or IR pyrometer to see how much heat it produces and where,
and what sort of convective flows are set up.
Depending on your convection flow results, you might want to think about
physically segregating your temperature sensor away from your circuitry,
by mounting the sensor in a plastic or cardboard tube within your
enclosure, say, so that ambient temperature air flow does not mix with
the convective flow your circuit is producing. You may need to extend
your sensor's leads for that. The tube would be mated to openings in
your enclosure at top and bottom.
In the last paragraph I mean to say "so that ambient temperature air
flow to_the_sensor does not mix with the convective heat air flow your
circuit is producing."
You can have a look at a ~17 min on demand video about a professional
thermal flow package called FloTherm at the Mentor Graphics website:
http://www.mentor.com/products/mechanical/products/flotherm
Unfortunately I couldn't see any evaluation/demo copies of this package.
Do a search for "computational fluid dynamics" and you might find some
packages with evaluation copies, or that are open source.
There is an open source CFD package that runs on various Linux flavours
at http://www.openfoam.com
You may do well to check out the Australian CSIRO online CFD resources
at http://www.cmis.csiro.au/cfd/
: Edited by User
Author: Anja (Guest)
Hello,
depending on the sensor used you have to regard self heating of the
sensor.
E.g. a LM335 used at 1mA will heat around 0.5-1 degrees (celsius) from
self heating in still air.
If you put the sensor at the bottom of the case and cut some slots into
the PCB to further isolate the sensor and use only low power for the
sensor (or pulsed usage) you should get the environment temperature with
below 1 deg C error.
Regards Anja
