Forum: FPGA, VHDL & Verilog error hdl compiler 164
Author: ISE xilinx (Guest)
hi I have the same problem and I do not know what I should do.
This is my vhdl code :
-- Company:
-- Engineer:
-- Create Date: 23:41:24 08/10/2013
-- Design Name:
-- Module Name: scrambler - Behavioral
-- Project Name:
-- Target Devices:
-- Tool versions:
-- Description:
-- Dependencies:
-- Revision:
-- Revision 0.01 - File Created
-- Additional Comments:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.NUMERIC_STD.ALL;
use STD.TEXTIO.ALL;
library WORK;
use WORK.pkgg.ALL;
--Library XilinxCoreLib;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity scrambler is
Port ( e : in STD_LOGIC_VECTOR (29 downto 0);
Sel : in STD_LOGIC_VECTOR (3 downto 0);
s : out STD_LOGIC_VECTOR (29 downto 0));
end scrambler;
architecture Behavioral of scrambler is
SIGNAL rst_n80220 : std_logic;
SIGNAL clk80220 : std_logic;
SIGNAL dout80220 : std_logic_vector(18 downto 0);
SIGNAL rst_n80216b : std_logic;
SIGNAL clk80216b : std_logic;
SIGNAL dout80216b : std_logic_vector(5 downto 0);
SIGNAL rst_n802154g : std_logic;
SIGNAL clk802154g : std_logic;
SIGNAL dout802154g : std_logic_vector(7 downto 0);
SIGNAL rst_nCDMA2000 : std_logic;
SIGNAL clkCDMA2000 : std_logic;
SIGNAL doutCDMA2000 : std_logic_vector(29 downto 0);
SIGNAL rst_nGPRS : std_logic;
SIGNAL clkGPRS : std_logic;
SIGNAL doutGPRS : std_logic_vector(5 downto 0);
SIGNAL rst_nGSM : std_logic;
SIGNAL clkGSM : std_logic;
SIGNAL doutGSM : std_logic_vector(23 downto 0);
SIGNAL rst_nHSDPA : std_logic;
SIGNAL clkHSDPA : std_logic;
SIGNAL doutHSDPA : std_logic_vector(14 downto 0);
SIGNAL rst_nIS95 : std_logic;
SIGNAL clkIS95 : std_logic;
SIGNAL doutIS95 : std_logic_vector(13 downto 0);
SIGNAL rst_nLTE : std_logic;
SIGNAL clkLTE : std_logic;
SIGNAL doutLTE : std_logic_vector(14 downto 0);
SIGNAL rst_nUMTS : std_logic;
SIGNAL clkUMTS : std_logic;
SIGNAL doutUMTS : std_logic_vector(15 downto 0);
SIGNAL rst_nWCDMA : std_logic;
SIGNAL clkWCDMA : std_logic;
SIGNAL doutWCDMA : std_logic_vector(23 downto 0);
SIGNAL rst_nDVB : std_logic;
SIGNAL clkDVB : std_logic;
SIGNAL doutDVB : std_logic_vector(13 downto 0);
width80220 : integer := 19;
length80220 : integer := 20;
taps80220 : T_LFSR_TAPS4 := (20, 19, 16, 14);
width80216b : integer := 6;
length80216b : integer := 7;
taps80216b : T_LFSR_TAPS6 := (7, 6, 5, 4, 3, 2);
width802154g : integer := 8;
length802154g : integer := 9;
taps802154g : T_LFSR_TAPS2 := (9, 4);
widthCDMA2000 : integer := 30;
lengthCDMA2000 : integer := 31;
tapsCDMA2000 : T_LFSR_TAPS16 := (31, 27, 26, 25, 22, 21, 19, 18, 17, 16,
10, 7, 6, 5, 3, 2);
widthGPRS : integer := 6;
lengthGPRS : integer := 7;
tapsGPRS : T_LFSR_TAPS2 := (7, 4);
widthGSM : integer := 24;
lengthGSM : integer := 25;
tapsGSM : T_LFSR_TAPS4 := (25, 20, 12, 8);
widthHSDPA : integer := 15;
lengthHSDPA : integer := 16;
tapsHSDPA : T_LFSR_TAPS4 := (16, 14, 13, 11);
widthIS95 : integer := 14;
lengthIS95 : integer := 15;
tapsIS95 : T_LFSR_TAPS6 := (15, 13, 9, 8, 7, 5);
widthLTE : integer := 15;
lengthLTE : integer := 16;
tapsLTE : T_LFSR_TAPS3 := (16, 12, 5);
widthUMTS : integer := 16;
lengthUMTS : integer := 17;
tapsUMTS : T_LFSR_TAPS2 := (17, 7);
widthWCDMA : integer := 24;
lengthWCDMA : integer := 25;
tapsWCDMA : T_LFSR_TAPS2 := (25, 3);
widthDVB : integer := 14;
lengthDVB : integer := 15;
tapsDVB : T_LFSR_TAPS2 := (15, 14);
component genlfsr80220
generic (
port (
rst_n80220 : in std_logic;
clk80220 : in std_logic;
dout80220 : out std_logic_vector(18 downto 0)
end component;
component genlfsr80216b
generic (
port (
rst_n80216b : in std_logic;
clk80216b : in std_logic;
dout80216b : out std_logic_vector(5 downto 0)
end component;
component genlfsr802154g
generic (
port (
rst_n802154g : in std_logic;
clk802154g : in std_logic;
dout802154g : out std_logic_vector(7 downto 0)
end component;
component genlfsrCDMA2000
generic (
10, 7, 6, 5, 3, 2)
port (
rst_nCDMA2000 : in std_logic;
clkCDMA2000 : in std_logic;
doutCDMA2000 : out std_logic_vector(29 downto 0)
end component;
component genlfsrGPRS
generic (
port (
rst_nGPRS : in std_logic;
clkGPRS : in std_logic;
doutGPRS : out std_logic_vector(5 downto 0)
end component;
component genlfsrGSM
generic (
port (
rst_nGSM : in std_logic;
clkGSM : in std_logic;
doutGSM : out std_logic_vector(23 downto 0)
end component;
component genlfsrHSDPA
generic (
port (
rst_nHSDPA : in std_logic;
clkHSDPA : in std_logic;
doutHSDPA : out std_logic_vector(14 downto 0)
end component;
component genlfsrIS95
generic (
port (
rst_nIS95 : in std_logic;
clkIS95 : in std_logic;
doutIS95 : out std_logic_vector(13 downto 0)
end component;
component genlfsrLTE
generic (
port (
rst_nLTE : in std_logic;
clkLTE : in std_logic;
doutLTE : out std_logic_vector(14 downto 0)
end component;
component genlfsrUMTS
generic (
port (
rst_nUMTS : in std_logic;
clkUMTS : in std_logic;
doutUMTS : out std_logic_vector(15 downto 0)
end component;
component genlfsrWCDMA
generic (
port (
rst_nWCDMA : in std_logic;
clkWCDMA : in std_logic;
doutWCDMA : out std_logic_vector(23 downto 0)
end component;
component genlfsrDVB
generic (
port (
rst_nDVB : in std_logic;
clkDVB : in std_logic;
doutDVB : out std_logic_vector(13 downto 0)
end component;
begin
U1: entity work.genlfsrWCDMA(behavioral)
generic map(widthWCDMA => widthWCDMA ,lengthWCDMA => lengthWCDMA
,tapsWCDMA => tapsWCDMA)
port map (rst_nWCDMA => rst_nWCDMA ,clkWCDMA => clkWCDMA ,doutWCDMA =>
doutWCDMA);
U2: entity work.genlfsrUMTS(behavioral)
generic map (widthUMTS => widthUMTS ,lengthUMTS => lengthUMTS ,tapsUMTS
=> tapsUMTS)
port map (rst_nUMTS => rst_nUMTS ,clkUMTS => clkUMTS ,doutUMTS
=>doutUMTS);
U3: entity work.genlfsrGSM(behavioral)
generic map (widthGSM => widthGSM ,lengthGSM => lengthGSM ,tapsGSM =>
tapsGSM)
port map (rst_nGSM => rst_nGSM ,clkGSM => clkGSM ,doutGSM =>doutGSM);
U4: entity work.genlfsrGPRS(behavioral)
generic map (widthGPRS => widthGPRS ,lengthGPRS => lengthGPRS ,tapsGPRS
=> tapsGPRS)
port map(rst_nGPRS => rst_nGPRS ,clkGPRS => clkGPRS ,doutGPRS
=>doutGPRS);
U5: entity work.genlfsrLTE(behavioral)
generic map (widthLTE => widthLTE ,lengthLTE => lengthLTE ,tapsLTE =>
tapsLTE)
port map(rst_nLTE => rst_nLTE ,clkLTE => clkLTE ,doutLTE =>doutLTE);
U6: entity work.genlfsrDVB(behavioral)
generic map (widthDVB => widthDVB ,lengthDVB => lengthDVB ,tapsDVB =>
tapsDVB)
port map(rst_nDVB => rst_nDVB ,clkDVB => clkDVB ,doutDVB =>doutDVB);
U7: entity work.genlfsrCDMA2000(behavioral)
generic map (widthCDMA2000 => widthCDMA2000 ,lengthCDMA2000 =>
lengthCDMA2000 ,tapsCDMA2000 => tapsCDMA2000)
port map(rst_nCDMA2000 => rst_nCDMA2000 ,clkCDMA2000 => clkCDMA2000
,doutCDMA2000 =>doutCDMA2000);
U8: entity work.genlfsr802154g(behavioral)
generic map (width802154g => width802154g ,length802154g =>
length802154g ,taps802154g => taps802154g)
port map(rst_n802154g => rst_n802154g ,clk802154g => clk802154g
,dout802154g =>dout802154g);
U9: entity work.genlfsr80220(behavioral)
generic map (width80220 => width80220 ,length80220 => length80220
,taps80220 => taps80220)
port map(rst_n80220 => rst_n80220 ,clk80220 => clk80220 ,dout80220
=>dout80220);
U10: entity work.genlfsr80216b(behavioral)
generic map (width80216b => width80216b ,length80216b => length80216b
,taps80216b => taps80216b)
port map(rst_n80216b => rst_n80216b ,clk80216b => clk80216b ,dout80216b
=>dout80216b);
U11: entity work.genlfsrHSDPA(behavioral)
generic map (widthHSDPA => widthHSDPA ,lengthHSDPA => lengthHSDPA
,tapsHSDPA => tapsHSDPA)
port map(rst_nHSDPA => rst_nHSDPA ,clkHSDPA => clkHSDPA ,doutHSDPA
=>doutHSDPA);
U12: entity work.genlfsrIS95(behavioral)
generic map (widthIS95 => widthIS95 ,lengthIS95 => lengthIS95 ,tapsIS95
=> tapsIS95)
port map(rst_nIS95 => rst_nIS95 ,clkIS95 => clkIS95 ,doutIS95
=>doutIS95);
process (doutGPRS,
doutCDMA2000,doutUMTS,doutGSM,doutLTE,doutDVB,doutWCDMA,dout802154g,dout
80220,  Sel) is
begin
s <= (others=>'0');
if Sel = "0000" then
s(29 downto 29-doutCDMA2000'high) <= doutCDMA2000 ;
elsif Sel = "0010" then
s(29 downto 29-doutGPRS'high) <= doutGPRS;
elsif Sel = "0100" then
s(29 downto 29-doutUMTS'high) <= doutUMTS;
elsif Sel = "0110" then
s(29 downto 29-doutGSM'high) <= doutGSM;
elsif Sel = "1000" then
s(29 downto 29-doutLTE'high) <= doutLTE;
elsif Sel = "1010" then
s(29 downto 29-doutDVB'high) <= doutDVB;
elsif Sel = "1100" then
s(29 downto 29-doutWCDMA'high) <= doutWCDMA;
elsif Sel = "0011" then
s(29 downto 29-dout80216b'high) <= dout80216b;
elsif Sel = "1001" then
s(29 downto 29-doutIS95'high) <= doutIS95;
elsif Sel = "0001" then
s(29 downto 29-doutHSDPA'high) <= doutHSDPA;
elsif Sel = "1111" then
s(29 downto 29-dout802154g'high) <= dout802154g;
else
s(29 downto 29-dout80220'high) <= dout80220;
end if ;
end process;
end Behavioral;
My probleme show in red and compilation of create timing constraints
with Project navigator ISE is :
ERROR:HDLParsers:164 -
"C:/Users/PROXIMEDIA/Documents/ISE-file/scrambler/scrambler.vhd" Line
93. parse error, unexpected IDENTIFIER
please help me
: Locked by Admin
Author: P. K. (pek)
Avoid multiple posts, or you may get your answer in an unexpected
position. Here the repost of my answer on your other input:
Try it with the keyword "SIGNAL" in front of your signal declarations.
Btw.: Formatted code as a VHDL attachment would ease things and increase
chance someone looking into your issue.
thanks for your attention
But if I try the keyword "SIGNAL" in front of your signal declarations
the error will be as follow :
ERROR:HDLCompiler:806 -
94: Syntax error near "length80220".
I don't understand what is my real error
 please help me
Author: Karl Könner (Guest)
Seems that starting from line 91 there a some malformed CONSTANT
declarations.
A constant declaration looks like:
CONSTANT the_answer : integer := 42;
Furthermore there are some user defined types (i.e. T_LFSR_TAPS4). maybe
the type definion is in none of your packages.
Best regards,
Author: P. K. (pek)
Do it either like this:
SIGNAL width80220 : integer := 19;
SIGNAL length80220 : integer := 20;
or like this:
CONSTANT width80220 : integer := 19;
CONSTANT length80220 : integer := 20;
Depending on your needs...
thank you very much
ISE xilinx wrote:
> width80220
> or like this:
width80220 is later used in a generic map where signals are not allowed.
So you need "CONSTANT", not "SIGNAL".
Greetings,
thank you for your attention
how to get a time report with ISE Project Navigator ?
Run timing analyzer, see atached screenshoot
thank you very much
when I run synthesize XST I find these warnings and I don't understand
its :
WARNING:Xst:819 -
"C:/Users/PROXIMEDIA/Documents/ISE-file/scrambler/scrambler.vhd" line
346: One or more signals are missing in the process sensitivity list. To
enable synthesis of FPGA/CPLD hardware, XST will assume that all
necessary signals are present in the sensitivity list. Please note that
the result of the synthesis may differ from the initial design
specification. The missing signals are:
   <dout80216b>, <doutIS95>, <doutHSDPA>
WARNING:Xst:647 - Input <e> is never used. This port will be preserved
and left unconnected if it belongs to a top-level block or it belongs to
a sub-block and the hierarchy of this sub-block is preserved.
WARNING:Xst:653 - Signal <rst_nWCDMA> is used but never assigned. This
sourceless signal will be automatically connected to value 0.
WARNING:Xst:653 - Signal <rst_nUMTS> is used but never assigned. This
WARNING:Xst:653 - Signal <rst_nLTE> is used but never assigned. This
WARNING:Xst:653 - Signal <rst_nIS95> is used but never assigned. This
WARNING:Xst:653 - Signal <rst_nHSDPA> is used but never assigned. This
WARNING:Xst:653 - Signal <rst_nGSM> is used but never assigned. This
WARNING:Xst:653 - Signal <rst_nGPRS> is used but never assigned. This
WARNING:Xst:653 - Signal <rst_nDVB> is used but never assigned. This
WARNING:Xst:653 - Signal <rst_nCDMA2000> is used but never assigned.
This sourceless signal will be automatically connected to value 0.
WARNING:Xst:653 - Signal <rst_n80220> is used but never assigned. This
WARNING:Xst:653 - Signal <rst_n80216b> is used but never assigned. This
WARNING:Xst:653 - Signal <rst_n802154g> is used but never assigned. This
WARNING:Xst:653 - Signal <clkWCDMA> is used but never assigned. This
WARNING:Xst:653 - Signal <clkUMTS> is used but never assigned. This
WARNING:Xst:653 - Signal <clkLTE> is used but never assigned. This
WARNING:Xst:653 - Signal <clkIS95> is used but never assigned. This
WARNING:Xst:653 - Signal <clkHSDPA> is used but never assigned. This
WARNING:Xst:653 - Signal <clkGSM> is used but never assigned. This
WARNING:Xst:653 - Signal <clkGPRS> is used but never assigned. This
WARNING:Xst:653 - Signal <clkDVB> is used but never assigned. This
WARNING:Xst:653 - Signal <clkCDMA2000> is used but never assigned. This
WARNING:Xst:653 - Signal <clk80220> is used but never assigned. This
WARNING:Xst:653 - Signal <clk80216b> is used but never assigned. This
WARNING:Xst:653 - Signal <clk802154g> is used but never assigned. This
WARNING:Xst:1710 - FF/Latch <regCDMA2000_19> (without init value) has a
constant value of 1 in block <U7>. This FF/Latch will be trimmed during
the optimization process.
WARNING:Xst:1710 - FF/Latch <regCDMA2000_20> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regCDMA2000_21> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regCDMA2000_22> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regCDMA2000_23> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regCDMA2000_24> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regCDMA2000_25> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regCDMA2000_26> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regCDMA2000_27> (without init value) has a
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch
<regWCDMA_24> (without init value) has a constant value of 1 in block
<U1>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <regGPRS_6>
(without init value) has a constant value of 1 in block <U4>. This
<reg80216b_6> (without init value) has a constant value of 1 in block
<U10>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1290 - Hierarchical block <U1> is unconnected in block
<scrambler>.
   It will be removed from the design.
WARNING:Xst:1290 - Hierarchical block <U2> is unconnected in block
<scrambler>.
WARNING:Xst:1290 - Hierarchical block <U3> is unconnected in block
<scrambler>.
WARNING:Xst:1290 - Hierarchical block <U4> is unconnected in block
<scrambler>.
WARNING:Xst:1290 - Hierarchical block <U5> is unconnected in block
<scrambler>.
WARNING:Xst:1290 - Hierarchical block <U6> is unconnected in block
<scrambler>.
WARNING:Xst:1290 - Hierarchical block <U7> is unconnected in block
<scrambler>.
WARNING:Xst:1290 - Hierarchical block <U8> is unconnected in block
<scrambler>.
WARNING:Xst:1290 - Hierarchical block <U9> is unconnected in block
<scrambler>.
WARNING:Xst:1290 - Hierarchical block <U10> is unconnected in block
<scrambler>.
WARNING:Xst:1290 - Hierarchical block <U11> is unconnected in block
<scrambler>.
WARNING:Xst:1290 - Hierarchical block <U12> is unconnected in block
<scrambler>.
WARNING:Xst:1710 - FF/Latch <regWCDMA_23> (without init value) has a
constant value of 1 in block <genlfsrWCDMA>. This FF/Latch will be
WARNING:Xst:1710 - FF/Latch <regWCDMA_22> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regWCDMA_21> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regWCDMA_20> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regWCDMA_19> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regWCDMA_18> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regWCDMA_17> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regWCDMA_16> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regWCDMA_15> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regWCDMA_14> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regWCDMA_13> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regWCDMA_12> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regWCDMA_11> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regWCDMA_10> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regWCDMA_9> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regWCDMA_8> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regWCDMA_7> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regWCDMA_6> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regWCDMA_5> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regWCDMA_4> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regWCDMA_3> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regWCDMA_2> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regWCDMA_1> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regWCDMA_0> (without init value) has a
<genlfsrWCDMA>. This FF/Latch will be trimmed during the optimization
process.
WARNING:Xst:1710 - FF/Latch <regUMTS_15> (without init value) has a
constant value of 1 in block <genlfsrUMTS>. This FF/Latch will be
WARNING:Xst:1710 - FF/Latch <regUMTS_14> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regUMTS_13> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regUMTS_12> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regUMTS_11> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regUMTS_10> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regUMTS_9> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regUMTS_8> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regUMTS_7> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regUMTS_6> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regUMTS_5> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regUMTS_4> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regUMTS_3> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regUMTS_2> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regUMTS_1> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regUMTS_0> (without init value) has a
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <regUMTS_16>
(without init value) has a constant value of 1 in block <genlfsrUMTS>.
WARNING:Xst:1710 - FF/Latch <regGSM_23> (without init value) has a
constant value of 1 in block <genlfsrGSM>. This FF/Latch will be trimmed
WARNING:Xst:1710 - FF/Latch <regGSM_22> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regGSM_21> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regGSM_20> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regGSM_19> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regGSM_18> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regGSM_17> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regGSM_16> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regGSM_15> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regGSM_14> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regGSM_13> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regGSM_12> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regGSM_11> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regGSM_10> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regGSM_9> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regGSM_8> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regGSM_7> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regGSM_6> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regGSM_5> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regGSM_4> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regGSM_3> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regGSM_2> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regGSM_1> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regGSM_0> (without init value) has a
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <regGSM_24>
(without init value) has a constant value of 1 in block <genlfsrGSM>.
WARNING:Xst:1710 - FF/Latch <regGPRS_0> (without init value) has a
constant value of 1 in block <genlfsrGPRS>. This FF/Latch will be
WARNING:Xst:1710 - FF/Latch <regGPRS_1> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regGPRS_2> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regGPRS_3> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regGPRS_4> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regGPRS_5> (without init value) has a
(without init value) has a constant value of 1 in block <genlfsrGPRS>.
WARNING:Xst:1710 - FF/Latch <regLTE_0> (without init value) has a
constant value of 1 in block <genlfsrLTE>. This FF/Latch will be trimmed
WARNING:Xst:1710 - FF/Latch <regLTE_1> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regLTE_2> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regLTE_3> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regLTE_4> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regLTE_5> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regLTE_6> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regLTE_7> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regLTE_8> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regLTE_9> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regLTE_10> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regLTE_11> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regLTE_12> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regLTE_13> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regLTE_14> (without init value) has a
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <regLTE_15>
(without init value) has a constant value of 1 in block <genlfsrLTE>.
WARNING:Xst:1710 - FF/Latch <regDVB_0> (without init value) has a
constant value of 1 in block <genlfsrDVB>. This FF/Latch will be trimmed
WARNING:Xst:1710 - FF/Latch <regDVB_1> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regDVB_2> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regDVB_3> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regDVB_4> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regDVB_5> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regDVB_6> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regDVB_7> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regDVB_8> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regDVB_9> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regDVB_10> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regDVB_11> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regDVB_12> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regDVB_13> (without init value) has a
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <regDVB_14>
(without init value) has a constant value of 1 in block <genlfsrDVB>.
WARNING:Xst:1710 - FF/Latch <regCDMA2000_29> (without init value) has a
constant value of 1 in block <genlfsrCDMA2000>. This FF/Latch will be
WARNING:Xst:1710 - FF/Latch <regCDMA2000_28> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regCDMA2000_18> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regCDMA2000_17> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regCDMA2000_16> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regCDMA2000_15> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regCDMA2000_14> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regCDMA2000_13> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regCDMA2000_12> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regCDMA2000_11> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regCDMA2000_10> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regCDMA2000_9> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regCDMA2000_8> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regCDMA2000_7> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regCDMA2000_6> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regCDMA2000_5> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regCDMA2000_4> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regCDMA2000_3> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regCDMA2000_2> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regCDMA2000_1> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regCDMA2000_0> (without init value) has a
<regCDMA2000_30> (without init value) has a constant value of 1 in block
<genlfsrCDMA2000>. This FF/Latch will be trimmed during the optimization
process.
WARNING:Xst:1710 - FF/Latch <reg802154g_0> (without init value) has a
constant value of 1 in block <genlfsr802154g>. This FF/Latch will be
WARNING:Xst:1710 - FF/Latch <reg802154g_1> (without init value) has a
WARNING:Xst:1710 - FF/Latch <reg802154g_2> (without init value) has a
WARNING:Xst:1710 - FF/Latch <reg802154g_3> (without init value) has a
WARNING:Xst:1710 - FF/Latch <reg802154g_4> (without init value) has a
WARNING:Xst:1710 - FF/Latch <reg802154g_5> (without init value) has a
WARNING:Xst:1710 - FF/Latch <reg802154g_6> (without init value) has a
WARNING:Xst:1710 - FF/Latch <reg802154g_7> (without init value) has a
<reg802154g_8> (without init value) has a constant value of 1 in block
<genlfsr802154g>. This FF/Latch will be trimmed during the optimization
process.
WARNING:Xst:1710 - FF/Latch <reg80220_18> (without init value) has a
constant value of 1 in block <genlfsr80220>. This FF/Latch will be
WARNING:Xst:1710 - FF/Latch <reg80220_17> (without init value) has a
WARNING:Xst:1710 - FF/Latch <reg80220_16> (without init value) has a
WARNING:Xst:1710 - FF/Latch <reg80220_15> (without init value) has a
WARNING:Xst:1710 - FF/Latch <reg80220_14> (without init value) has a
WARNING:Xst:1710 - FF/Latch <reg80220_13> (without init value) has a
WARNING:Xst:1710 - FF/Latch <reg80220_12> (without init value) has a
WARNING:Xst:1710 - FF/Latch <reg80220_11> (without init value) has a
WARNING:Xst:1710 - FF/Latch <reg80220_10> (without init value) has a
WARNING:Xst:1710 - FF/Latch <reg80220_9> (without init value) has a
WARNING:Xst:1710 - FF/Latch <reg80220_8> (without init value) has a
WARNING:Xst:1710 - FF/Latch <reg80220_7> (without init value) has a
WARNING:Xst:1710 - FF/Latch <reg80220_6> (without init value) has a
WARNING:Xst:1710 - FF/Latch <reg80220_5> (without init value) has a
WARNING:Xst:1710 - FF/Latch <reg80220_4> (without init value) has a
WARNING:Xst:1710 - FF/Latch <reg80220_3> (without init value) has a
WARNING:Xst:1710 - FF/Latch <reg80220_2> (without init value) has a
WARNING:Xst:1710 - FF/Latch <reg80220_1> (without init value) has a
WARNING:Xst:1710 - FF/Latch <reg80220_0> (without init value) has a
<reg80220_19> (without init value) has a constant value of 1 in block
<genlfsr80220>. This FF/Latch will be trimmed during the optimization
process.
WARNING:Xst:1710 - FF/Latch <reg80216b_0> (without init value) has a
constant value of 1 in block <genlfsr80216b>. This FF/Latch will be
WARNING:Xst:1710 - FF/Latch <reg80216b_1> (without init value) has a
WARNING:Xst:1710 - FF/Latch <reg80216b_2> (without init value) has a
WARNING:Xst:1710 - FF/Latch <reg80216b_3> (without init value) has a
WARNING:Xst:1710 - FF/Latch <reg80216b_4> (without init value) has a
WARNING:Xst:1710 - FF/Latch <reg80216b_5> (without init value) has a
<genlfsr80216b>. This FF/Latch will be trimmed during the optimization
process.
WARNING:Xst:1710 - FF/Latch <regHSDPA_0> (without init value) has a
constant value of 1 in block <genlfsrHSDPA>. This FF/Latch will be
WARNING:Xst:1710 - FF/Latch <regHSDPA_1> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regHSDPA_2> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regHSDPA_3> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regHSDPA_4> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regHSDPA_5> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regHSDPA_6> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regHSDPA_7> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regHSDPA_8> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regHSDPA_9> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regHSDPA_10> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regHSDPA_11> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regHSDPA_12> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regHSDPA_13> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regHSDPA_14> (without init value) has a
<regHSDPA_15> (without init value) has a constant value of 1 in block
<genlfsrHSDPA>. This FF/Latch will be trimmed during the optimization
process.
WARNING:Xst:1710 - FF/Latch <regIS95_0> (without init value) has a
constant value of 1 in block <genlfsrIS95>. This FF/Latch will be
WARNING:Xst:1710 - FF/Latch <regIS95_1> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regIS95_2> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regIS95_3> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regIS95_4> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regIS95_5> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regIS95_6> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regIS95_7> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regIS95_8> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regIS95_9> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regIS95_10> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regIS95_11> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regIS95_12> (without init value) has a
WARNING:Xst:1710 - FF/Latch <regIS95_13> (without init value) has a
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <regIS95_14>
(without init value) has a constant value of 1 in block <genlfsrIS95>.
Author: Andreas Schwarz (andreas) (Admin) Flattr this
These warnings should be very clear to someone with even just a basic
understanding of VHDL. Please make at least a minimal effort to solve
problems on your own before you ask in this forum. Asking here is not a
replacement for learning VHDL.
This topic is locked and can not be replied to.
