Forum: µC & Digital Electronics Recommendation for board?
von Gomp Fruktpastiller (Guest)
I'm looking for a board for bare-metal programming. Following features
are "must-haves":
- 2 analogue outputs with at least 16 bit resolution (real analogue
outputs, no PWM-tricks and no audio-channels)
- one digital input and one digital output
- at least 50 MHz CPU clock (so that the application is able to switch
the outputs fast enough)
- Ethernet and/or USB
Optionally:
- 3 analogue outputs / better resolution
- more digital outputs
- PWM/frequency outputs
- ARM CPU
- community/example codes so that the Ethernet/USB stack doesn't have to
be developed from scratch
Any ideas which board could be used?
Thanks!
von Andreas (Guest)
PSoC5LP from Cypress would fit,
Cypress also offers a development board.
Also
http://www.powerfulboard.com/node/21
would do it, for USD 50.
Andreas
