Forum: FPGA, VHDL & Verilog timing constraint
Author: ISE xilinks (Guest)
""ERROR:HDLParsers:3305 -
"C:/Users/PROXIMEDIA/Documents/ISE-file/scrambler/scrambler.vhd" Line
301.  The actual value (Signal 'widthWCDMA') associated with a generic
must be a globally static expression.""
How shall we do it?
ISE xilinks wrote:
> How shall we do it?
You already DID it.
The actual question must be: how can we avoid it?
And then it would be VERY helpful to see the code that results in the
posted problem. Or how the heck should anyone find out what the problem
may be?
But usually this error results from dynamic borders or ranges that
should or must be static when synthesizing the design...
BTW: by reading the word "scrambler" i become kind of suspicious:
http://embdev.net/search?query=scrambler
Author: Dajana Kroh (hummer90)
okay, without any code it is definitely a bit difficult to solve the
problem.
But the compiler has a problem with your definition in your entity.
You declared some "constant" value in your generic section in your
entity and the compiler wants a constant in the architecture I think.
Maybe it could fix your problem.
Regards
  • [vhdl]VHDL code[/vhdl]
