Hello,
I am just a college student, I am trying to improve my knowledge of
Verilog :) Now I am working with an Altera DE0-Nano. What I would like
to achieve is pretty simple: a shift register that shifts to the left
with one button and to the right with another one. My first draft was
the following one, but it did not work.
1 | module led_shift(UP, DOWN, RES, CLK, LED);
2 | input UP, DOWN, RES, CLK;
3 | output reg [7:0] LED;
4 | reg [7:0] STATE;
5 |
6 | always@(negedge DOWN or negedge UP or negedge RES)
7 | begin
8 | if(!RES)
9 | begin
10 | STATE <= 8'b00010000;
11 | end
12 | else
13 | begin
14 | STATE <= UP ? STATE>>1 : STATE<<1;
15 | end
16 | end
17 |
18 | always @ (posedge CLK)
19 | begin
20 | LED <= STATE;
21 | end
22 | endmodule
The problem was, that it was not clear for the synthesizer to know how
to control STATE with the 3 asynchronous control signals, so I was told
to use the technique of clock domain crossing. To simplify more, I
decided to work with only the left shift, and this is the second draft.
2 |
3 | input UP, DOWN, RES, CLK;
4 | output reg [7:0] LED;
5 | reg [7:0] STATE;
6 | reg pre_sync_UP, sync_UP;
7 |
8 |
9 | always @(posedge CLK) begin
10 | if(!RES) begin
11 | LED = 8'b00000001;
12 | end
13 | else begin
14 | pre_sync_UP <= UP;
15 | sync_UP <= pre_sync_UP;
16 | LED <= STATE;
17 | end
18 | end
19 |
20 | always@(sync_UP or pre_sync_UP) begin
21 | if(sync_UP && !pre_sync_UP) begin
22 | STATE <= LED << 1;
23 | end
24 | else begin
25 | STATE <= LED;
26 | end
27 | end
28 |
29 |
30 | endmodule
(Istead of
I also tried the xor, but it did not work)
Unfortunately it does not work at all, after putting the RES at 1, it
seems that the shift is always performed, even without pressing the
button. I can not see why, though. Someone can help me?
Thanks!
