Forum: ARM programming with GCC/GNU tools arm cross compiler
von david d. (Company: upmc) (davee)
Hello,
I am trying to install the cross-compiler for the processor arm on
ubuntu 10.04
I installed binutils-2.20, gcc-4.4.2 and gdb-6.7.1.
to install gcc, I used these commands:
1)
sudo .. / ../../src/gcc-4.4.2/configure --prefix=/usr/local/SocLib/
toolchain/arm --target=arm-unknown-elf --program-prefix=arm-unknown-elf
-- disable-nls --disable-werror --enable-languages​​=c --disable-libssp
--disable-threads --without-headers.
2) sudo make
3) sudo make install.
After these steps, a file will be generated automatically
"arm-unknown-elf-gcc", but the problem is that I find
"arm-unknown-elf-gcc-4.4.2".
how to solve this problem.
thank you in advance
von profWho (Guest)
Unfortunatly have the same error,
still looking for the result?
or have you found something?
von Uwe Bonnes (Guest)
Try the packages found at
https://launchpad.net/gcc-arm-embedded
They work for me out of the box for Opensuse 12.3 on X86-64.
Bye
von Rene H. (Guest)
Hi David,
did you already tried a symbolic link? I guess this should solve your
issue.
Cheers,
René
