Forum: µC & Digital Electronics AVR32 uc3c startup troubleshooting
von hBechtold (Guest)
Hello,
I'm working on a board as follows: own design with at32uc3c2256,
Ethernet PHY TI/National DP83484I, 3.3 Volt supply local from DC/DC
converter, a few gpio pins, PWM, TWI, no use of ADC/DAC, but analog
power supply connected to 3.3 V and bypassed, as recommended. The master
clock is external osc. 25 MHz, obtained by dividing the 50 MHz PHY clock
by two.
The software uses FreeRTOS and the lwip stack from AVR Studio 6  ASF
libs.
We build five prototype boards, six layer pcb according to Atmel and TI
design recommendations. After fixing some minor hardware and software
bugs, two of the five boards work pretty well, including Ethernet
operation, after flashing and starting via JTAG, as well as powered up
stand allone.
But the boards no. 3 to 5 show a strange behaviour: They work perfectly,
including ethernet, if flashed and started via the JTAGICE3 debugger by
means of the AVR studio. After booting the target, I even can quit the
debugger, pull the JTAG connector off and the board continues to run.
But if I start the board without JTAG, the CPU seems not to run at all.
The PHY works, lights its 'link' LED when connecting the Ethernet cable,
even the 'activity' LED flashes if I try a ping to the target's address.
But the CPU seems not to execute a single line of code. I placed a
couple of bit toggles onto some unused gpio pins, they work perfecty
when starting the target via the studio, but I can't measure a single
edge there if the target was powered up stand allone.
All voltages and (external) clocks are ok, the same as when the board
runs.
The debugger doesn't help much, because the system runs pretty well when
JTAG connected and started by the studio. If I press the reset button
after quitting the debug session in the studio, while still having JTAG
connected, the target resets, but does not start again, so the pure
electric connection to the JTAGICE3 seems not to play a role.
Any ideas about troubleshooting strategies?
How can I reset the target without flashing and without the
unconditional stop in the first line of 'main.c'?
Horst
Hello again,
it's always the simple things which cause the worst headaches!
I found it by myself, here for all the others, trapping into the same
hole:
After a hardware reset, the hardware watchdog may be enabled, depending
on the fuse settings. In the software, the first thing we coded, was to
disable the watchdog by calling the ASF driver function "wdt_disable()",
which resets the enable bit in the AVR32_WDT control register. But this
function has never been called because the watchdog time setting was far
too short for reaching that function call.
When flashing these chips the first time, don't forget to disable the
watchdog in the WDTDISRV fuse bit first, otherwise the processor may run
into an infinite loop by permanently resetting itself.
The JTAG debugger broke this loop by intervening via hardware and when
starting the user code at main(), the driver function was called at
first, seemingly solving the problem, so that it was impossible to find
the bug by means of the debugger only.
Horst
von Bruno K. (Guest)
Hi hBechtold,
thanks for telling us your solution. We had the same Problem!
Bruno
von Alen (Guest)
Hi Horst
You just saved me hours (maybe days) of struggle, as first google result
was your post.
Just so you know - there is one person on planet who'll be always
grateful for this post.
All the best
Alen
