Forum: FPGA, VHDL & Verilog to_unsigned()
von Meli (Guest)
Dear all,
I've got a problem with to_unsigned(). I'm using the code below for a
test-bench, but an error occures while simulating the code if using
"Enable optimization", or a FATAL error while loading the design.
My Code is:
 TDinput (line_width-1 downto 0)<= std_logic_vector (to_unsigned(43,line_width));
while TDinput is an STD_LOGIC_VECTOR, and line_width is an INTEGER.
The error is :
# ** Error: C:/Users/Melika/Desktop/Advanced VLSI/Assignment
4/GenMux/MUX_behav/2/Generic_mux1.vhd(26): (vopt-1144) Value -7 is out
of std.standard.natural range 0 to 2147483647.
4/GenMux/MUX_behav/2/Generic_mux1.vhd(26): (vopt-1153) Index value -7 is
out of index range of ieee.std_logic_1164.std_logic_vector; it is less
than 0.
Please give me a hint to resolve the problem. THANKS
von Martin (Guest)
try this.
x  <= to_unsigned(2, x'length);
Is it a constant integer?
What value does it have?
Where comes the -7 from?
The problem is not located in the posted line.
Pls. attach the complete *.vhdl file...
von Meli (Guest)
@ Martin:
I've also tried that, but the same error is stucked!
@  Lothar Miller :
The line_width is a generic integer with the initial value of 8. First,
I thought -7 is related to the inital value of the line_width, but as u
can see in the code, it doesn't seem like it is related to that.
By the way, the whole error comments continues from -7 to -1 !!
Meli wrote:
>   TB.txt
*.txt ist not *.vhdl
There is a reason why I wrote *.vhdl explicitly: the board software
recognizes file types with the file extension, and it supports syntax
highlighting for known file types...
The problem is not in the posted code.
I took it, added the missing component and: it simulates perfect. See
the attached files...
> use IEEE.std_logic_arith.all;
> use IEEE.std_logic_unsigned.all;
> use IEEE.numeric_std.all;
Use the first two or the last one, but never ever all three of them
together! Otherwise you can observe strange messages now and then...
von Meli (Guest)
Dear Lothar,
I didn't know about the borad software, sorry!
And thank you for your quick reply.
The line u added for the test vectors is not needed since the select
line is 3-bit selecting between 0 to 7.
But any way, U did really help. Thank u so much.
I'm so glad that I visited your site by chance. I'm a fan from now on
Recalculate this once more and you will see: 0..7 are 8 positions.
Therefore 8 positions must be initialized (according to your own
testbench). And for the highest bit position it is 8*8-1 = 63. You can
see this in the Waveform when tsel is 7: the value 12 (i added) is
visible on toutput...
> Thank u so much.
You're welcome... ;-)
von Meli (Guest)
Thanks Lothar. Yeh, u'r right.
Thanks again and have fun :-D
