Hello , Sincerly i'm newbie i'm not familiar with FPGA I'm using the spartan6 and i have to communicate this fpaga with a DDR3 , so i used the MIG from COrgen , after that i'm using the example design which i removed all files of Traffic generator and i remplaced it by my onwn user interface which i use a state machie to read and Write DATA ? but my broblem now : firstly afetr generation of this part of project , how can i use it into my top project ( the other projet which i have designed my work) if that is the case i'm asking if i'll add all the source files palced in the rtl folder or not ? - secondely i want to modify data written and readen into the memory , how can i use the procedure , i need simple example :( - a little more question : i have to to use the data such as input std_logic but this type INPUT it could be readen and written ? - also someone can explain me how to modify and what is the difference between these parmeters : constant C3_CLKOUT0_DIVIDE : integer := 1; constant C3_CLKOUT1_DIVIDE : integer := 1; constant C3_CLKOUT2_DIVIDE : integer := 16; constant C3_CLKOUT3_DIVIDE : integer := 8; constant C3_CLKFBOUT_MULT : integer := 2; constant C3_DIVCLK_DIVIDE : integer := 1; Please any help
i am also working on MIG core from xilinx. I simulate it through generate simulated file..can you help me complete understanding of this core how they work...plz reply through email..mhamzahab@gmail.com
