Forum: Analog Circuits MAX4619 latch up at control voltage of 1.5V
von Peter (Guest)
I ran some tests with a MAX4619 chip (Datasheet:
http://datasheets.maximintegrated.com/en/ds/MAX4617-MAX4619.pdf)
and I recognized 2 things:
1. At a loadcurrent of about 9mA there was a current of around 3mA
coming out of the GND-terminal. This is not a big Problem, just tell me
if thats normal please.
2. This is realy a problem: If I go up or down with my control/trigger
voltage (at e.g. terminal B) rather slowly, there is a latch up occuring
as soon as I reach 1.5V (from either side)
When I added a diode at Vcc and at GND terminals (as described in the
datasheet) the voltage region where the latch up occurs seemed to be
extended to 1.5V-1.7V
other conditions:
Vcc = 5V
Analog signal Voltage 0V or 5V
Thanks for your help, I realy appreciate it!
von Julian G. (Company: NSW TAFE College Mt Druitt) (my_other_head)
2. According to the given datasheet, in the Electrical Characteristics
table on page 2, Digital I/O section, you're operating in the undefined
logic state for this device, or any 5V/ТТL logic device for that matter.
Any particular reason why?
A low state,  a '0', for the control lines of this device is any voltage
between 0 to 0.8V, and a high state, a '1', is defined as any voltage
higher than 2.4V to Vcc. Anything in between
i.e. 0.8V‹ V‹ 2.4V, will be in an undeterminable state.
For reasons why this occurs, read up on totem-pole configurations, and
TTL and CMOS logic gate topologies in any introductory college/uni text
on digital logic, e.g. Tocci or Wakerley. (I presume you know how a
transistor works in switching mode?) This will also explain your first
query point.
A reference I thoroughly recommend to anyone learning or experimenting
with analogue or digital electronics, or even professionally, is "The
Art of Electronics", 2ed, by Paul Horowitz and Winfield Hill, 1989,
Cambridge Uni Press, aka "The Silver Bible". It's even available in its
entirety of 1125pp. on the web. Worth every cent if you decide to buy
it, although some of the later chapters on microprocessors are a bit
dated, but useful all the same for understanding modern
microcontrollers.
Peter, if for some reason your control logic voltages are not in the
specified ranges from wherever they are coming from, you will have to
think about about converting them, with a level converter, for instance,
or putting them through a comparator.
