Design the baud rate synchronizes transmitter and receiver of UART. Clock divider in UART play important role as it provides appropriate frequency clock as per required by the baud rate. The calculation of baud rate divider required following formula: No. of Counts= (FPGA Freq/Baud Rate)/2 Design a module which takes four Baud Rates 600,1200,2400,4800 and provide the divided clock freq. accordingly. module ClockDivider(input Clk,output BClk,input [1:0]BSel); //BClk-Baud Clock //Clk-input Clock // BSel-Baud Rate Select, 00-600, 01-1200,10-2400, 11-4800 Endmodule how should i write the verilog code for this.... Please help me
Look at site 7 in this document: http://www.dsi.fceia.unr.edu.ar/downloads/DDA/UART_Manual.pdf There is a clock divider example. Cihan
momina nisar wrote: > how should i write the verilog code for this.... The firstmost step: You should have a look how others did similar prescalers. And then you take that formula and implement a counter which is reloaded with the appropriate value for the one of the 4 desired frequencies. About 10 lines of code and you're done... Cihan Kalayci wrote: > There is a clock divider example. Seems to be the wrong HDL... ;-)
No this is not home work i once read a buk in which it was a question and now i forget the buk even
