I am a university student. These days I am doing my final year project on fpga. I need to interface ad7478 ADC to FPGA. I am going to filter a 500kHz signal.So I need atleast 1MSPS adc. I go through the data sheet, but didn't got an idea how to interface it with FPGA. I need help ....
interfacing an adc needs basically a counter and a if-then-based or case construct based timing which can directly be taken from the data sheet typing fpga code for this requires basic knowledge in verilog you should have studied that at your "university" getting help in a forum moreover requires a detailled decription of what you have and what you want to do this is also a thing, what universities should teach students, in my opinion it furthermore requires the focus an a particular question not how to do something in general, you do not really expect others to do your work? why don't you ask your mentor at the university?
You only need a shift Register, a counter and a simple state machine to control CS. The interface looks quite simple
> I go through the data sheet, Thats a good point to start... > but didn't got an idea how to interface it with FPGA. Hmm, you didn't figure out, that you need 3 wires between the 2 components: two FPGA outputs (a ChipSelect and a SCLK signal) and one input (the SDATA). With these signals the interface between ADC and FPGA is done... And now you must have a look for the timing, and generate this behaviour with a few lines of code. A maximum of 30 lines of code (maybe Verilog or even VHDL) will do the job. At last a short testbench to check the timing against the datasheet. And then your done with the whole interface. > I need help .... No one is intended to do your homework. So you must offer some effort on your own. And when a problem arises you can ask a particular question. But not one like "Who wants to do my job?"
