Good morning I have an error on my vhdl file, I would affect e to one of my component list (scramblerUMTS, scramblerGSM, etc...) when sel is 000 or 0001 etc... please I need a reply tnx
>> "Cannot drive signal 'e' of mode IN" << Whats not clear with this error message? If e is an input you cannot assign a value to it... > I would affect e to one of my component list I do not unterstand the problem. e is used nowhere inside the code...
so what the new type of e to will can assibne a value ???
I'm sorry, I don't have even the faintest idea what your problem is... You cannot assign a value to e from inside the comp_sc module. You can assign values to a local signal. Likewise you did with this ones:
1 | SIGNAL data_in_WCDMA : std_logic_vector (24 downto 0); |
2 | SIGNAL scram_en_WCDMA: std_logic; |
3 | SIGNAL scram_rst_WCDMA: std_logic; |
4 | :
5 | :
thank you for explaination it joined a picture of my project implementation, you can help me ? thank you in advance
That does not match in width:
1 | e : in std_logic_vector ; |
2 | |
3 | data_in_WCDMA : in std_logic_vector (24 downto 0); |
And you cannot assign a unconstrained vector (e) to some other vectors with different widths. As it it not necessary to multiplex the inputs (just think about that for half an hour), you must only have an eye on the outputs. Finally you must input a vector at least the size of the broadest module vector (here this is 42 bits) and you must select the interesting result to the output.
1 | LIBRARY ieee ; |
2 | USE ieee.std_logic_1164.all ; |
3 | USE ieee.std_logic_arith.all ; |
4 | ENTITY comp_sc IS |
5 | port ( e : in std_logic_vector (41 downto 0); |
6 | Sel : in std_logic_vector (2 downto 0); |
7 | s : out std_logic_vector (41 downto 0) |
8 | );
9 | END ; |
10 | ARCHITECTURE arch_comp_sc OF comp_sc IS |
11 | :
12 | :
13 | SIGNAL data_in_GPRS : std_logic_vector (6 downto 0); -- the smallest |
14 | SIGNAL data_out_GPRS : std_logic_vector (6 downto 0); |
15 | :
16 | :
17 | SIGNAL data_in_CDMA2000 : std_logic_vector (41 downto 0); -- the broadest |
18 | SIGNAL data_out_CDMA2000 : std_logic_vector (41 downto 0); |
19 | :
20 | :
21 | BEGIN
22 | data_in_CDMA2000 <= e; |
23 | data_in_GPRS <= e(6 downto 0); |
24 | :
25 | :
26 | process (data_out_GPR, data_out_CDMA2000, Sel) is |
27 | begin
28 | s <= (others => '0'); -- assign a default value to unused output bits |
29 | case Sel is |
30 | when "000" => s <= data_out_CDMA2000; |
31 | when "001" => s <= data_out_GPRS; |
32 | when "010" => ... |
33 | when "011" => ... |
34 | :
35 | end case; |
36 | end process; |
37 | :
BTW: you did some simple&stupid copy&paste work without thinking. How much clocks do you have? Ho much resets and enables? Where do the come from?
thank you a lot :) I have 1 clk and 2 resets (scram_rst_WCDMA,rst_WCDMA) in every component
good morning please can you tell me what is the name of this step in vhdl programmation ?
