Forum: µC & Digital Electronics LCD interface with Dev board
von Brandon S. (brandon_s)
I had this working LCD code that used Port 0. Now I tried to change to
PORT 1.
Attached is my code. Is there something wrong in my code?
I am sure of my hardware. Checked every connection and I already tested
my board with a simple LED blinky so I think my start up configuraton is
oki.
I appreciate if you can guide me of any mistake. I also tried to
simulate with ISIS however I am getting an error of Vin..
thanks
#include <lpc21xx.h>
#define buzz 1<<25 /*lcd rs pin*/
#define pin_rs 1<<21 /*lcd rs pin*/
#define pin_rw 1<<23 /*lcd rw pin*/
#define pin_en 1<<20 /*lcd en pin*/
#define pin_ctrl pin_rs|pin_rw|pin_en /*lcd control pins. pin_ctrl include all 4 [pin_rs, pin_rw, pin_en]*/
#define lcd_d4 1<<16 /*lcd data pins D4,D5,D6,D7*/
#define lcd_d5 1<<17
#define lcd_d6 1<<18
#define lcd_d7 1<<19
#define lcd_data lcd_d4|lcd_d5|lcd_d6|lcd_d7 /*lcd_data include all 4 [lcd_d4, lcd_d5, lcd_d6, lcd_d7]*/
#define lcd_rs(x) ((x)?(IOSET1 = pin_rs):(IOCLR1 = pin_rs));  /*lcd_rs(x) if x=1 will set the lcd_rs pin will clear if x=0*/
#define lcd_rw(x) ((x)?(IOSET1 = pin_rw):(IOCLR1 = pin_rw));  /*lcd_rw(x) if x=1 will set the lcd_rs pin will clear if x=0*/
#define lcd_en(x) ((x)?(IOSET1 = pin_en):(IOCLR1 = pin_en));  /*lcd_en(x) if x=1 will set the lcd_rs pin will clear if x=0*/
#define data_in ((IOPIN0>>10)&(0x0F)) /*direction of the data pins as input*/
#define data_out(x) IOCLR0 = lcd_data; IOSET0 = (x & 0x0F)<<10; /*direction of the data pins and control pins as output*/
#define lcd_all_dir_out IODIR0 |= lcd_data ; IODIR1 |= pin_ctrl; /*setting as output for both data and control pins*/
#define lcd_dir_data_out IODIR0 |= lcd_data     /*set*/
#define lcd_dir_data_in IODIR0 &= ~(lcd_data)   /*clear*/
30
#define lcd_clear lcd_cmd_write(0x01);
31
32
33
34
static void delay(int);
35
36
37
static void delay(int cnt)
38
39
  cnt <<= 4;
40
  while(cnt--);   //delay
41
42
43
static unsigned char busy_wait()
44
45
  unsigned char (status);
46
  do
47
48
    lcd_dir_data_in;//set pins as inputs
49
    lcd_rs(0);  // rs=0 indecates that data is being passed
50
    lcd_rw(1);  // rw=0 indicates that Read function is enabled
51
    lcd_en(1);  //enabeled
52
    delay(10);
53
    status = (data_in << 4)&(0xF0); //data_in shift by 4 AND 0xF0
54
    lcd_en(0);  //disabled
55
    delay(10);
56
57
    delay(10);
58
    status |= data_in; //bit wise OR
59
60
    lcd_dir_data_out;  //set pins as outputs
61
    delay(10);
62
63
  while(status & 0x80);  //bit wise AND
64
  return (status);
65
66
67
void lcd_write_4bit(unsigned char c)
68
69
  lcd_rw(0);  // rw=0 indicates that Read function is enabled
70
  lcd_en(1);  // enables the lcd
71
  data_out(c & 0x0F);//bit wise AND
72
  data_out(c);
73
  delay(10);
74
  lcd_en(0);
75
  delay(10);
76
77
78
static void lcd_cmd_write(unsigned char c)
79
80
  busy_wait();
81
  lcd_rs(0); // 0 indecates that data is being passed
82
  delay(10);
83
  lcd_write_4bit(c >> 4);// c is shifted to the right by 4 and passed to lcd_write_4bit()
84
  lcd_write_4bit(c);  // c is passed to lcd_write_4bit()
85
86
87
static void lcd_data_write(unsigned char c)
88
89
  busy_wait(); //
90
  lcd_rs(1);  // 1 indecates that a command is being passed
91
  delay(10);
92
93
94
95
96
static void lcd_init()
97
98
  lcd_all_dir_out; //set pins as outputs
99
  delay(10);
100
101
  lcd_write_4bit(0x3);
102
  delay(10);
103
104
  delay(10);
105
106
  lcd_write_4bit(0x2);
107
108
  lcd_cmd_write(0x28); // 1 01000 = 1[(0)DL (1)N (0)F (0)* (0)*]   Sets interface data length (DL) number of display lines (L) and character font(F).
109
  lcd_cmd_write(0x0C); // 1 100 = 1[(1)Disp (0)Cursor (0)Blink] display ON curser OFF   blink OFF
110
  lcd_cmd_write(0x06); // courser auto increment
111
112
113
void lcd_print(unsigned char const *mess)
114
115
  while(*mess)
116
117
    lcd_data_write(*mess++);//repeats this function for every constant in string mess
118
119
120
121
122
int main(void)
123
124
  PINSEL2 &= 0x0;//SET IO PORT FUNCTIONALITY
125
  IODIR1 = 0xFFFF; //set all as outpuT
126
127
  delay(1000);
128
129
  lcd_init();    //initilize lcd
130
  lcd_clear;    //clears lcd
131
132
  lcd_print("test");   //used for testing
133
  delay(1000);
134
135
136
while(1);
137
138
von Andreas (Guest)
You are still using the IO registers for port 0 in some of the
definitions. Change them all, then it should work.
