Forum: µC & Digital Electronics Header for PIC16F688 with C-Compiler
von Stefan Hölfer (Guest)
Hi, first of all: I´m new to coding for PICs. I´m trying to code my very
first programm in C. I´m using MPLAB IDE v8.90 with HI-TECH ANSI
C-Compiler.
I used to code some minor programms in Java so I decided to code in C.
Assembler seems very difficult to me. So my question is. I want to
configure my PIC16F688 with internal clock so that it lights up and
blinks a LED. The coding is not the biggest problem. My problem is the
configuration of the PICs Pins (include/header). I hope you guys can
help me with this and give me an advices and maybe a description what to
do.
von Erich (Guest)
Use GOOGLE to look for example projects and learn from them!
  "PIC16F688" project  "Hi-tech" Compiler
  "PIC16F688" project  "Hitech" Compiler
  "PIC16F688" project  "Hi-tech" Compiler mcp "source code"
regards
von Stefan H. (stefan_h68)
Thank you for the quick answer.
I already used google but I cant find anythig which helps me. I just
need to configure the pins and how to implement them in code and how to
set up the clock
Edit: or can you recommend an other IDE or programming tool?
von c_prog (Guest)
Ok real quick:
It seems like you're actually trying, unlike a few other posts I've seen
here where the OP is basically asking for someone to design a complete
board for them with very little information.
The OSCCON register sets the internal clock frequency.  Just worry about
bits 6 through 4.  The others shouldn't matter.
Next you have to config the pin connected to the LED as an output.  Say
you want to use pin 8; you'd have to clear bit 2 of TRISC since pin 8 is
bit 2 of port C.  The bits in a TRIS register must be cleared to make it
an output, and set to make it an input (think 1 for input, 0 for
output).
Sometimes there's a register that configs a pin for use with the A/D, or
as a digital pin.  I don't see it on this chip.
As for the configuration bits (what is set in MPLAB, page 111 of
datasheet), make sure the watchdog is disabled for now, WDTE, and set
FOSC to binary 100.  That sets it to use the internal oscillator.  Make
sure the MCLR pin is pulled to +5 so it doesn't get stuck in reset.
As for the format of how to write to these registers, look at some
examples provided with HITECH.  I don't recall how that one works.  You
could take a look at my website.  I have some example code on there for
other PICS.  Actually, now that I think about it, I believe the single
digit clock I have there uses the 688.
http://users9.nofeehost.com/jmiller/
