Hi i have a problem in calling module in verilog that when i call a module that make alot of calculation( module calc) it gives me the o/p delayed a clock and also another module for ram and module for rom thats also delay one clock so when i take the delayed o/p from the (module calc) and but it in the (module RAM) it put the values at wrong places in the ram. module calc is consists of a module for lookuptable(module LUT) and another module for adding and subtract floating point(module addsub). i need a form of module that doesn't delay (what could make a delay in a module to avoid) because my system is consists of alot of modules in side each other. please help me if you can or if you have any suggestion.
Well, you are rather vague on how the modules operate... you seem to want combinatorial results and you get clocked results. That seems to lead to timing problems. I'd suggest you get GTKWave, for instance, and analyze those vcd files in detail to see when the data arrive and when it is supposed to arrived. A better/detailed explanation of what you have may also help...
