Why am I getting the erros at the end Process and end architecture? Thanks Martin
For one thing, these lines should be 'end if' and not 'endif' if in_1 = '1' then out_1 <= '1' after 2ns ; endif; if in_1 = '0' then out_1 <= '0' after 2ns ; endif; if in_2 = '1' then out_2 <= '1' after 2ns ; endif;
And also in VHDL every process must have a sensitivity list or a wait statement inside. The process in question doesn't have any of them... I strongly recommend to take any book about VHDL and have a look for the keyword /loop/:
1 | loop
2 | ...
3 | end loop; |
That book about VHDL will also help you with the next steps. As an alternative you can use Google and have a look how others are doing VHDL...
Thanks That solved the first problem. Still have the other problem, is it because I used basic in architecture? I am using "The Designer's Guide to VHDL" second edition by Peter J. Ashenden The templet came from page 14. I am using Altera Max V Quartus II. Just trying to understand to process from design to program. Martin
