Forum: ARM programming with GCC/GNU tools linker sections not considered
von alex o. (Company: none) (pointdexter)
Hy forum,
I tried for several days to see how GNU arm behaves. I'm stuck into a
loop here. I could use some help.
I have a linker script that contains:
    . = ORIGIN(flash);
     vectors :
        *(.vectors)
    } >flash
    . = 0x000001F0;
     .text :
        *(.text)
        *(.rodata)
        *(.rodata*)
        _end_text = .;
    } >flash
then somewhere in the code I do something like
_attribute_ ((section(".vectors")))
void NMI_Handler(void)
  int a=0;
  a++;
_attribute_ ((section(".text")))
void Reset_Handler(void)
    unsigned int *src, *dst;
the meaning of this code is not important as it is not correct
However I would expect function Reset_Handler to start from 1F0, yet in
the lst file I see it starting from 2c    :|  ??
Second question
I would like to do something like
asm(".section .vectors");
asm("B Reset_Handler");
however when I see into the lst file...same problem... a function main
that is supposed to go into .text beginning with 1F0 or higher, appears
at 0x0 :|
What am I missing here?
I would appreciate some input.
Thanks
von MacLyon (Guest)
Check this link: http://www.emb4fun.de/arm/examples/index.html it
provides some good examples and contain also a linker file - suppose you
are using a Cortex micro...
MacLyon
