Forum: ARM programming with GCC/GNU tools help Yagarto linking 32 bit arm code into CM4
von magnetron (Guest)
hello forum,
a simple math calculation caused my STM32F4 going into hardfault
first I asked my problem at ST forum
however it turned out that my eclipse + yagarto is the cause of the
problem
it is linking 32 bit ARM code instead of THUMB code for my STM32F4 uC
please have a look at ;
https://my.st.com/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Flat.aspx?RootFolder=%2fpublic%2fSTe2ecommunities%2fmcu%2fLists%2fcortex%5fmx%5fstm32%2fSTM32F4%20simple%20math%20calculation%20causes%20hardfault&FolderCTID=0x01200200770978C69A1141439FE559EB459D7580009C4E14902C3CDE46A77F0FFD06506F5B&TopicsView=https%3A%2F%2Fmy%2Est%2Ecom%2Fpublic%2FSTe2ecommunities%2Fmcu%2FLists%2Fcortex%5Fmx%5Fstm32%2FAllItems%2Easpx&currentviews=51
what is your advice for me to proceed ?
thank you
von hnuneüpe (Guest)
General hint (does not necessarily solve the prob):
>$(LD) $(LDFLAGS) -T$(LINKER_SCRIPT) -o $(OUTPUT).out $(C_OBJECTS)
$(ASM_OBJECTS) -lm libgcc.a
You didn't present your def of $(LD), but it smells like you are calling
the linker directly there.
Usually it is advisable to use gcc also for the linking step,
i.e.
LD = arm-none-eabi-gcc
rather than
LD = arm-none-eabi-ld
(or whatever prefix the yagarto tools are using) and then omit
the libgcc.a from the command.
The gcc compiler driver has built-in intelligence to link the
proper runtime libs - depending on the mach options it is passed.
And when specifying a lib on the command line, the usual syntax is
-lgcc to link a lib named libgcc.a (in the same way as -lm links a
lib named libm.a - the "lib" prefix and ".a" suffix are omitted ). But
that might be handled differently between Unix and
Windows platforms.
Also have the linker produce a map file and verify that the right libs
are
linked.
von Michael F. (mifi)
Hello magnetron,
use this example here:
http://www.emb4fun.de/download/arm/examples/STM32F407Test.zip
Add your code:
  float hypo2;
  int32_t XH=7,YH=8;
  hypo2= (XH*(XH*1.0) + YH*(YH*1.0));
It will work :o)
As hnuneüpe has written before, do not use the linker
direct. Use the GCC for linking too. At my page you will
find some small examples to start:
http://www.emb4fun.de/arm/examples/index.html
Best regards,
Michael
hello,
I changed this line from
>$(LD) $(LDFLAGS) -T$(LINKER_SCRIPT) -o $(OUTPUT).out $(C_OBJECTS) >$(ASM_OBJECTS)
-lm libgcc.a
to
-lm
and the error was removed
thank you for your answers
note: I was already using gcc instead of ld
