Forum: FPGA, VHDL & Verilog Digital to analog converter in ModelSim
von nelson g. (Company: student) (together)
Is there a way to simulate a digital to analog converter in
ModelSim????? I have my Verilog code that produces the 16 bit input to a
DAC . It would be really nice if I could somehow see the analog waveform
in simulation...
: Locked by Moderator
von P. K. (pek)
You could write your own behaviour model, if timing etc. is important.
Otherwise, if you just want to see an analog representation of your
digital value, use the context menu in your wave table (right-click on
the signal name), then in the context menu use > Format > Analog. Ther
exists a version (automatic) and (custom). Automatic may serve as a
start, use custom to fit your needs afterwards.
> in simulation...
So just change the view (right click on the signals name in the
waveform) of that particular waveform. So you can select amongst
"vector", "signed decimal", "unsinged decimal", ... and "analog". Then
you get something like that:
http://www.lothar-miller.de/s9y/categories/38-LFSR
http://www.lothar-miller.de/s9y/archives/38-DDFS-mit-Distributed-ROM.html
And of course there's google:
https://www.google.de/search?q=modelsim+analog+waveform
von Manfred (Guest)
I think it is not just the analog view, he needs, but the timing of a
ADC. Some of them have parallel interfaces with criital PLL issues and
others come with I2C for instance.
What I also directly thought of, when reading this issue, was the
modelling of the anti aliasing Filter in VHDL. Anybody did this already?
von Surender (Guest)
pls i need digital to analog converter coding..pls send me sir
Why hijacking an old zombie thread for a NEW question?
> pls send me sir
Usually we do it that way: YOU say in detail what you need (what HDL?
what DAC? what interface?)and then YOU show what YOU already have and
what problems you encounter with that. Then WE discuss some solutions
and YOU implement them.
But we don't do YOUR homework.
And if its no homework, but instead commercially: what do you need and
what do you PAY for that solution?
This topic is locked and can not be replied to.
