Forum: FPGA, VHDL & Verilog VHDL Synthesis
Author: Vibhuti R. (vibhuti_r)
I have written 2 state machines in my VHDL code. The simulation works
fine, but the code does not synthesize. Any help would be appreciated.
Here is my code:
    library IEEE;
    use IEEE.STD_LOGIC_1164.ALL;
    use IEEE.STD_LOGIC_arith.ALL;
    use IEEE.STD_LOGIC_unsigned.ALL;
    use IEEE.NUMERIC_STD.ALL;
    entity pulse_width is
    Port (  clk : in STD_LOGIC;
          timer2:in std_logic;
          input: in STD_LOGIC;
          result: inout STD_LOGIC_VECTOR (15 downto 0);
          SEL_LINE: IN STD_LOGIC_VECTOR(5 DOWNTO 0);
          data_out: out STD_LOGIC_VECTOR (23 downto 0):=x"000000");
    end pulse_width;
    architecture Behavioral of pulse_width is
      TYPE count_states is (s0,s0_dash,s1,s2,s3,s1_dash);
      SIGNAL current_state, next_state : count_states := s0 ;
      TYPE write_states is (ws0,ws0_dash,ws1,ws2,ws3,ws4);
      SIGNAL current_state1, next_state1 : write_states := ws0 ;
      TYPE index_array is ARRAY(integer range 0 to 65535) of
std_logic_vector(15 downto 0);
      SIGNAL mem: index_array;
      SIGNAL count: std_logic_vector(15 downto 0):=x"0000";
      SHARED VARIABLE j: integer:=0;
      SHARED VARIABLE a,i: integer:=1;
      SIGNAL
flag,push_data,push_first,push_final,push_pulses,rw_first,rw_end:
std_logic:='0';
      SIGNAL y_clk_input ,y_clk_timer2, enable_count: std_logic:='0';
      SIGNAL first,final: std_logic_vector(15 downto 0):= x"0001";
    begin
    -- Pulse width count
    process (clk)
    begin
      if rising_edge(clk) then
        current_state<=next_state;
        current_state1<=next_state1;
      end if;
    end process;
    process(input,SEL_LINE,current_state)
    begin
      case current_state is
      when s0 =>
        if(input='1') then
          next_state<=s1;
        else
          next_state<=s0;
        end if;
      when s1 =>
        flag<='0';
        if input='1' then
          count <= count+ x"0001";
          next_state<=s1_dash;
        else
          next_state<=s2;
        end if;
      when s1_dash =>
        if input='1' then
          next_state<=s1;
        else
          next_state<=s2;
        end if;
      when s2 =>
          result <= count;
          next_state<=s3;
      when s3=>
          count <= x"0000";
          next_state<=s0;
          enable_count<='0';
      when others =>
        next_state<=s0;
      end case;
      case current_state1 is
      when ws0 =>
        if  (result>x"0000") then
        next_state1<=ws1;
        else
        next_state1<=ws0_dash;
        end if;
      when ws0_dash =>
        next_state1<=ws1;
        else
        next_state1<=ws0;
        end if;
      when ws1=>
        if rw_first='1' and rw_end='1' then
        next_state1<=ws0;
        else
          mem(a) <= result;
          a:=a+1;
          final<=final+x"0001";
          next_state1<=ws2;
        end if;
      when ws2 =>
          next_state1<=ws0;
          result<=x"0000";
      when others  =>
        next_state1<=ws0;
      end case;
    end process;
I eventually need to implement three state machines.
Author: Duke Scarring (Guest)
> The simulation works fine, but the code does not synthesize.
What is the error message?
Duke
> Duke
Hi Duke,
I am using Xilinx 13.2. The code gets stuck in the synthesis part and
does not complete the process. Hence no error message is visible.
Is it the synthesizer that stucks or is it one of the later steps?
Which target (Virtex, Spartan)? And which FPGA size?
Try the new parser:
http://www.lothar-miller.de/s9y/archives/79-use_ne...
Where did you see this?
Do never ever use them three together!
Otherwise you will have curious effects due to double definitions of
types and arithmetics.
Why all of them in 1 process?
    begin
      when s2 =>
          result <= count;
Your simulation is wrong because to count is missing in the
sensitivity list.
      TYPE index_array is ARRAY(integer range 0 to 65535) of std_logic_vector(15 downto 0);
Does your FPGA have that much RAM?
Are you sure you need those?
And: never use unconstrained integers.
  • [vhdl]VHDL code[/vhdl]
