Forum: FPGA, VHDL & Verilog sdram controller read/write need help
Author: ladybird (Guest)
hello all. please i need some help
i would like to display two images on a vga screen. and i'm using the
sdram to temporarely save frames before display. when i was using only
one image i didn't have any problem i had two write fifo and two read
fifo. but when i attempt to write/read another image means i added two
other FiFOs for the write and two other read Fifos for the read, i get a
mess on the vga display, knowing that i added a display module to decide
where to display the image since i divided the screen into 2. below is
an excerpt of the sdram control code
if (WR1_LOAD)
        rWR1_ADDR    <= WR1_ADDR;
      else
    if (mWR_DONE&&WR_MASK[0])
        begin
            if (rWR1_ADDR<WR1_MAX_ADDR-WR1_LENGTH)
                rWR1_ADDR    <= rWR1_ADDR+WR1_LENGTH;
            else
        end
        //    Write Side 2
    if (WR2_LOAD)
        rWR2_ADDR    <= WR2_ADDR;
        else if (mWR_DONE&&WR_MASK[1])
        begin
            if (rWR2_ADDR<WR2_MAX_ADDR-WR2_LENGTH)
                rWR2_ADDR    <=    rWR2_ADDR+WR2_LENGTH;
            else
        end
//    Write Side 3
    if (WR3_LOAD)
        rWR3_ADDR    <= WR3_ADDR;
      else
    if (mWR_DONE&&WR_MASK[2])
        begin
            if (rWR3_ADDR<WR3_MAX_ADDR-WR3_LENGTH)
                rWR3_ADDR    <= rWR3_ADDR+WR3_LENGTH;
            else
        end
        //    Write Side 4
    if (WR4_LOAD)
        rWR4_ADDR    <= WR4_ADDR;
        else if (mWR_DONE&&WR_MASK[3])
        begin
            if (rWR4_ADDR<WR4_MAX_ADDR-WR4_LENGTH)
                rWR4_ADDR    <=    rWR4_ADDR+WR4_LENGTH;
            else
        end
    //    Read Side 1
      if (RD1_LOAD)
            rRD1_ADDR    <= RD1_ADDR;
        else if (mRD_DONE&&RD_MASK[0])
        begin
            if (rRD1_ADDR<RD1_MAX_ADDR-RD1_LENGTH)
                rRD1_ADDR    <=    rRD1_ADDR+RD1_LENGTH;
            else
        end
        //    Read Side 2
        if (mRD_DONE&&RD_MASK[1])
        begin
            if (rRD2_ADDR<RD2_MAX_ADDR-RD2_LENGTH)
                rRD2_ADDR    <=    rRD2_ADDR+RD2_LENGTH;
            else
                rRD2_ADDR    <=    RD2_ADDR;
        end
    //    Read Side 3
      if (RD3_LOAD)
            rRD3_ADDR    <= RD3_ADDR;
        else if (mRD_DONE&&RD_MASK[2])
        begin
            if (rRD3_ADDR<RD3_MAX_ADDR-RD3_LENGTH)
                rRD3_ADDR    <=    rRD3_ADDR+RD3_LENGTH;
            else
        end
        //    Read Side 4
        if (mRD_DONE&&RD_MASK[3])
        begin
            if (rRD4_ADDR<RD4_MAX_ADDR-RD4_LENGTH)
                rRD4_ADDR    <=    rRD4_ADDR+RD4_LENGTH;
            else
                rRD4_ADDR    <=    RD4_ADDR;
        end
    end
in  the main program the sdram is mapped this way
    Sdram_Control    u7    (    //    HOST Side
                                .RESET_N(KEY[0]),
                                .CLK(sdram_ctrl_clk),
    //                            //    FIFO Write Side 1
                                .WR1_DATA({1'b0,sCCD_G[11:7],sCCD_B[11:2]}),
                                .WR1(sCCD_DVAL),
                                .WR1_ADDR(0),
                               .WR1_MAX_ADDR(640*480/2),
                               .WR1_LENGTH(8'h50),
                                .WR1_LOAD(!DLY_RST_0),
                                .WR1_CLK(PIXCLK),
    //                            //    FIFO Write Side 2
                                .WR2_DATA({1'b0,sCCD_G[6:2],sCCD_R[11:2]}),
                                .WR2(sCCD_DVAL),
                                .WR2_ADDR(23'h25800),
                               .WR2_MAX_ADDR(23'h25800+640*480/2),
                                .WR2_LENGTH(8'h50),
                                .WR2_LOAD(!DLY_RST_0),
                                .WR2_CLK(PIXCLK),
    //                            //    FIFO Write Side 3
                                .WR3_DATA(data_test1),
                                .WR3(valid),
                                .WR3_ADDR(23'h60000),
                               .WR3_MAX_ADDR(23'h85800),
                               .WR3_LENGTH(8'h50),
                                .WR3_LOAD(!DLY_RST_0),
                                .WR3_CLK(PIXCLK),
                                .WR4_DATA(data_test2),
                                .WR4(valid),
                                .WR4_ADDR(23'h90000),
                               .WR4_MAX_ADDR(23'h90000+640*480/2),
                                .WR4_LENGTH(8'h50),
                                .WR4_LOAD(!DLY_RST_0),
                                .WR4_CLK(PIXCLK),
                                //    FIFO Read Side 1
                               .RD1_DATA(Read_DATA1),
                                .RD1(vga_read),
                                .RD1_ADDR(0),
                               .RD1_MAX_ADDR(640*480/2),
                                .RD1_LENGTH(8'h50),
                                .RD1_LOAD(!DLY_RST_0),
                                .RD1_CLK(~VGA_CTRL_CLK),
    //                            //    FIFO Read Side 2
                                .RD2_DATA(Read_DATA2),
                                .RD2(vga_read),
                                .RD2_ADDR(23'h25800),
                                .RD2_MAX_ADDR(23'h25800+640*480/2),
                                .RD2_LENGTH(8'h50),
                                .RD2_LOAD(!DLY_RST_0),
                                .RD2_CLK(~VGA_CTRL_CLK),
    //////                            //    FIFO Read Side 1
                                .RD3_DATA(Read_DATA3),
                                .RD3(vga_read),
                              .RD3_ADDR(23'h60000),
                              .RD3_MAX_ADDR(23'h85800),
                               .RD3_LENGTH(8'h50),
                                .RD3_LOAD(!DLY_RST_0),
                                .RD3_CLK(~VGA_CTRL_CLK),
                               .RD4_DATA(Read_DATA4),
                              .RD4(vga_read),
                               .RD4_ADDR(23'h90000),
                                .RD4_MAX_ADDR(23'h90000+640*480/2),
                            .RD4_LENGTH(8'h50),
                              .RD4_LOAD(!DLY_RST_0),
                               .RD4_CLK(~VGA_CTRL_CLK),
                                //    SDRAM Side
                                .SA(DRAM_ADDR),
                                .BA(DRAM_BA),
                                .CS_N(DRAM_CS_N),
                                .CKE(DRAM_CKE),
                                .RAS_N(DRAM_RAS_N),
                                .CAS_N(DRAM_CAS_N),
                                .WE_N(DRAM_WE_N),
                                .DQ(DRAM_DQ),
                                .DQM(DRAM_DQM)
i've a DE2-115 Board and i'm using quartus 10.0
Thank u
Author: dave (Guest)
Hi Ladybird,
do u already solved  your problem?
I also need to implement a controller of the sdram, but I have problems
to run it oin the board. May be we can change some ideas.
cheers, Dave
Author: Wayne Gretzky (Guest)
Maybe you sit done and write some block diagram first to show people
what you want to knwo and what you did? Nobody want's to guess it from a
non working code.
  • [vhdl]VHDL code[/vhdl]
