Forum: ARM programming with GCC/GNU tools unknown cpu 'cortex-m0'
von Evert (Guest)
Dear all,
I have some serious issues with the GCC compiler when using a cortex-M0
(STM32F051)
When compiling my code with GCC version 4.6.3, which should support
cortex-M0 microcontrollers, I get next messages:
Error: unknown cpu `cortex-m0'
Error: unrecognized option -mcpu=cortex-m0
When compiling the same code with the codesourcery lite package (same
gcc version), it works fine, however I like to configure my own gcc
version.
I configured GCC with next options:
  ../configure --target=arm-axon-eabi --prefix=toolchain \
    --with-cpu=cortex-m0 --with-mode=thumb \
    --enable-interwork --disable-multilib \
    --enable-languages="c" --with-newlib --without-headers \
    --disable-shared --with-gnu-as --with-gnu-ld \
    2>&1 | tee configure.log
Looking in the logging, the cortex-m0 is recognized
Also with the newest version 4.7.2 I have the same problems
Who can help me with this issue?
Regards,
Evert
von Marces E. (Guest)
I use an Arduino... Maybe it helps, if you write: "-mmcu=", but I'm not
sure, just test it...
MfG Marces
von mthomas (Guest)
Binutils up-to-date?
von user (Guest)
I use this congfiguration:
../gcc-4.6-4.6.3/gcc-4.6.3/configure --target=arm-none-eabi
--enable-interwork --enable-multilib --enable-languages=c,c++
--with-newlib
--with-headers=/home/user/gcc-4.6.3/newlib-1.18.0/newlib/libc/include
--disable-libssp --disable-nls --with-system-zlib
--prefix=/home/user/gcc-4.6.3/gcc-4.6.3-install
--with-mpc=/home/user/gcc-4.6.3/gcc-4.6.3-install
--with-mpfr=/home/user/gcc-4.6.3/gcc-4.6.3-install
--with-gmp=/home/user/gcc-4.6.3/gcc-4.6.3-install
and I replaced the file gcc-4.6-4.6.3/gcc-4.6.3/gcc/config/arm/t-arm-elf
with the attached file
von MacLyon (Guest)
Try this cross-compiler:
https://launchpad.net/gcc-arm-embedded
it is dedicated for various versions of cortex processors. On this page
there is a readme link with info about (I use this for cm3 and cm4).
MacLyon
von Benedikt (Guest)
Depending on where that Error came from exactly, the issue might be
similiar to one I had with AVRs.
There avr-gcc would not complain about -mmcu=atmega8 while avr-ld does
only accept architecture names, i.e. --mmcu=avr4 .
von Jörg W. (dl8dtl) (Moderator)
Run it as "arm-...-gcc --target-help", and it will tell you which
CPU types are recognized.
I've got an elderly GCC 4.6.0 around, and it properly supports
Cortex-M0 CPUs:
$ arm-none-eabi-gcc --target-help
The following options are target specific:
  -mabi=                      Specify an ABI
  -mabort-on-noreturn         Generate a call to abort if a noreturn function
                              returns
  -mapcs-float                Pass FP arguments in FP registers
  -mapcs-frame                Generate APCS conformant stack frames
  -mapcs-reentrant            Generate re-entrant, PIC code
  -march=                     Specify the name of the target architecture
  -mbig-endian                Assume target CPU is configured as big endian
  -mcallee-super-interworking Thumb: Assume non-static functions may be called
                              from ARM code
  -mcaller-super-interworking Thumb: Assume function pointers may go to non-
                              Thumb aware code
  -mcirrus-fix-invalid-insns  Cirrus: Place NOPs to avoid invalid instruction
                              combinations
  -mcpu=                      Specify the name of the target CPU
  -mfix-cortex-m3-ldrd        Avoid overlapping destination and address
                              registers on LDRD instructions that may trigger
                              Cortex-M3 errata.
  -mfloat-abi=                Specify if floating point hardware should be used
  -mfp16-format=              Specify the __fp16 floating-point format
  -mfpu=                      Specify the name of the target floating point
                              hardware/format
  -mhard-float                Alias for -mfloat-abi=hard
  -mlittle-endian             Assume target CPU is configured as little endian
  -mlong-calls                Generate call insns as indirect calls, if
                              necessary
  -mpic-register=             Specify the register to be used for PIC addressing
30
  -mpoke-function-name        Store function names in object code
31
  -msched-prolog              Permit scheduling of a function's prologue
32
                              sequence
33
  -msingle-pic-base           Do not load the PIC register in function prologues
34
  -msoft-float                Alias for -mfloat-abi=soft
35
  -mstructure-size-boundary=  Specify the minimum bit alignment of structures
36
  -mthumb                     Compile for the Thumb not the ARM
37
  -mthumb-interwork           Support calls between Thumb and ARM instruction
38
                              sets
39
  -mtp=                       Specify how to access the thread pointer
40
  -mtpcs-frame                Thumb: Generate (non-leaf) stack frames even if
41
                              not needed
42
  -mtpcs-leaf-frame           Thumb: Generate (leaf) stack frames even if not
43
                              needed
44
  -mtune=                     Tune code for the given processor
45
  -mvectorize-with-neon-quad  Use Neon quad-word (rather than double-word)
46
                              registers for vectorization
47
  -mword-relocations          Only generate absolute relocations on word sized
48
                              values.
49
  -mwords-little-endian       Assume big endian bytes, little endian words
50
51
  Known ARM CPUs (for use with the -mcpu= and -mtune= options):
52
    cortex-m0, cortex-m1, cortex-m3, cortex-m4, cortex-r4f, cortex-r4,
53
    cortex-a15, cortex-a9, cortex-a8, cortex-a5, arm1156t2f-s, arm1156t2-s,
54
    mpcore, mpcorenovfp, arm1176jzf-s, arm1176jz-s, arm1136jf-s, arm1136j-s,
55
    arm1026ej-s, arm926ej-s, fa726te, fmp626, fa626te, fa606te, iwmmxt2, iwmmxt,
56
    xscale, arm1022e, arm1020e, arm10e, arm968e-s, arm966e-s, arm946e-s, arm9e,
57
    arm1020t, arm10tdmi, ep9312, arm940t, arm922t, arm920t, arm920, arm9tdmi,
58
    arm9, arm740t, arm720t, arm710t, arm7tdmi-s, arm7tdmi, fa626, fa526,
59
    strongarm1110, strongarm1100, strongarm110, strongarm, arm810, arm8,
60
    arm7dmi, arm7dm, arm7m, arm7500fe, arm7500, arm7100, arm710c, arm720,
61
    arm710, arm700i, arm700, arm70, arm7di, arm7d, arm7, arm620, arm610, arm600,
62
    arm60, arm6, arm3, arm250, arm2
63
64
  Known ARM architectures (for use with the -march= option):
65
    iwmmxt2, iwmmxt, ep9312, armv7e-m, armv7-m, armv7-r, armv7-a, armv7,
66
    armv6-m, armv6t2, armv6zk, armv6z, armv6k, armv6j, armv6, armv5te, armv5e,
67
    armv5t, armv5, armv4t, armv4, armv3m, armv3, armv2a, armv2
68
Assembler options
69
70
