The code written below is according to the Image attached of an I2C master controller, i am having difficulties to make the Vhdl file for every block instead of all in a single file. thank you. library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; use ieee.std_logic_unsigned.all; entity i2c_master_registers is port ( wb_clk_i : in std_logic; rst_i : in std_logic; wb_rst_i : in std_logic; wb_dat_i : in std_logic_vector(7 downto 0); wb_adr_i : in std_logic_vector(2 downto 0); wb_wacc : in std_logic; i2c_al : in std_logic; i2c_busy : in std_logic; done : in std_logic; irxack : in std_logic; prer : out std_logic_vector(15 downto 0); -- clock prescale register ctr : out std_logic_vector(7 downto 0); -- control register txr : out std_logic_vector(7 downto 0); -- transmit register cr : out std_logic_vector(7 downto 0); -- command register sr : out std_logic_vector(7 downto 0) -- status register ); end; architecture arch of i2c_master_registers is signal ctr_int : std_logic_vector(7 downto 0); signal cr_int : std_logic_vector(7 downto 0); signal al : std_logic; -- status register arbitration lost bit signal rxack : std_logic; -- received aknowledge from slave signal tip : std_logic; -- transfer in progress signal irq_flag : std_logic; -- interrupt pending flag begin -- generate prescale regisres, control registers, and transmit register process(wb_clk_i,rst_i) begin if (rst_i = '0') then prer <= (others => '1'); ctr_int <= (others => '0'); txr <= (others => '0'); elsif rising_edge(wb_clk_i) then if (wb_rst_i = '1') then prer <= (others => '1'); ctr_int <= (others => '0'); txr <= (others => '0'); elsif (wb_wacc = '1') then case (wb_adr_i) is when "000" => prer(7 downto 0) <= wb_dat_i; when "001" => prer(15 downto 8) <= wb_dat_i; when "010" => ctr_int <= wb_dat_i; when "011" => txr <= wb_dat_i; when others => NULL; end case; end if; end if; end process; ctr <= ctr_int; -- generate command register (special case) process(wb_clk_i,rst_i) begin if (rst_i = '0') then cr_int <= (others => '0'); elsif rising_edge(wb_clk_i) then if (wb_rst_i = '1') then cr_int <= (others => '0'); elsif (wb_wacc = '1') then if ((ctr_int(7) = '1') AND (wb_adr_i = "100")) then cr_int <= wb_dat_i; end if; else if ((done = '1') OR (i2c_al = '1')) then cr_int(7 downto 4) <= "0000"; -- clear command b end if; -- or when aribitr cr_int(2 downto 1) <= "00"; -- reserved bits cr_int(0) <= '0'; -- clear IRQ_ACK b end if; end if; end process; cr <= cr_int; -- generate status register block + interrupt request signal -- each output will be assigned to corresponding sr register locations on top level process(wb_clk_i,rst_i) begin if (rst_i = '0') then al <= '0'; rxack <= '0'; tip <= '0'; irq_flag <= '0'; elsif rising_edge(wb_clk_i) then if (wb_rst_i = '1') then al <= '0'; rxack <= '0'; tip <= '0'; irq_flag <= '0'; else al <= i2c_al OR (al AND NOT(cr_int(7))); rxack <= irxack; tip <= (cr_int(5) OR cr_int(4)); irq_flag <= (done OR i2c_al OR irq_flag) AND NOT(cr_int(0)); -- interrupt request flag is always generated end if; end if; end process; sr(7) <= rxack; sr(6) <= i2c_busy; sr(5) <= al; sr(4 downto 2) <= "000"; -- reserved sr(1) <= tip; sr(0) <= irq_flag; end arch;
