Forum: µC & Digital Electronics AVR Studio - ATmega8 - display f_cpu on lcd
von micro u. (Guest)
hi
all this program should do is do print 2 lines:
1.) either "f ok" or "f not ok"
2.) f_cpu = 3686400
but all i get is:
1.) f not ok
2.) f_cpu = 0016384
i noticed that the factor between those 2 numbers is 225,.. no clue why!
i dont really get it.
#define should replace in the pre-prossessor every "F_CPU" with
"3686400" right?
so if i write
const int freq = F_CPU;
 its exactly the same to
const int freq = 3686400;
 isnt it?
thanks for ur help
luk
#define F_CPU 3686400   // max 3686400 = 3,6MHz
#include <avr/io.h>
#include <util/delay.h>
//#include <stdio.h>
#include "lcd-routines.h"
#include <math.h>
int temp = 0;
int counter = 0;
int main(void){
  lcd_init();
  for(counter = 7; counter>=0; counter--){
    temp = freq * pow(10, -(counter-1));
    if(counter==7){
      if(freq==3686400){
        lcd_string("f ok");
      } else {
        lcd_string("f not okay");
      lcd_setcursor( 0, 2 );
      lcd_string("F_CPU = ");
30
    for( ; temp>=10; ){
31
      temp = temp%10;
32
33
34
    switch(temp){
35
      case 0:  lcd_string("0"); break;
36
      case 1:  lcd_string("1"); break;
37
      case 2:  lcd_string("2"); break;
38
      case 3:  lcd_string("3"); break;
39
      case 4:  lcd_string("4"); break;
40
      case 5:  lcd_string("5"); break;
41
      case 6:  lcd_string("6"); break;
42
      case 7:  lcd_string("7"); break;
43
      case 8:  lcd_string("8"); break;
44
      case 9:  lcd_string("9"); break;
45
46
47
48
49
   return 0;
50
von Peter II (Guest)
int is 16bit!
3686400 neet more then 16bit.
von mschoeldgen (Guest)
Even if your int really is a 16-bit int, it would never do to store
3686400 in it.
You'll have to declare your variable a 'long' and then store F_CPU in
it. The result is a truncation of 3686400 = 0x384000 to the lower 2
bytes resulting in 0x4000 = 16384.
yes??
i thought that int is 16-32 bit, so it is -2^31 to 2^31-1, which is much
bigger than 3.6MHz
anyway, i check it. thanks for your help
Well, your posted results clearly show that your int is a 16bit int. Its
one of the reasons why we tend to use explicit varibales these days, as
int differs from one architecture to the next.
If you use e.g. 'uint32_t' the problem never arises as you know its a
32 bit number.
