Forum: µC & Digital Electronics AVR Studio - ATmega8 - Beginner
Author: micro u. (Guest)
-1 useful
Hi
im trying to get used to avr studio.
the program shut turn a led on and off in a period of, lets say 1
second.
i got now two possible ways, to achieve this function:
first, im gonna define f_cpu 1 per second and let the led change every
loop. or, 2nd, im gonna let the frequency of the cpu as it is and sleep
every loop 1 second.
but both ways seem not to work at all.
Questions:
1.) where can i get information about the order of including librarys
and definitions about my hardware. i was told to be carefully about the
order.
2.) is the way im defining my f_cpu correct? can i freely choose between
1Hz and a bit over 3MHz??
3.) when i choose to use the _delay_ms(5000) function, how does this
function work? if i say _delay_ms(5000);, does the program wait there
for 5 seconds and then keep going??
4.) any  ideas for improvement in this program?
thanks for your help
AVR Studio - Program for Test board (myAVR MK2)
File    :
User    :
Datum    :
Version    :
Function  :
call input EXAMPLE
  if(!(PIND & 0x04)){
// HARDWARE SETTINGS & LIBRARYS
//      BEWARE! ORDER MUST BE KEPT AS IT IS
#include <avr/io.h>        // Header for AVR (type of uC)
#ifndef  F_CPU          // must be written before delay.h
#define  F_CPU 1000UL      // loop frequency
#endif
#include <stdio.h>        // standard library
//#include <stdint.h>        // standardized data types
#include <util/delay.h>      // time delay
//#include <avr/interrupt.h>     // interrupt????
                //#include <windows.h>
//#include <avr/sleep.h>
// PROTOTYPE
void initPorts(void);
int testing(void);
// STRUCTURES
// GLOBAL VARIABLES
int counter = 0;
int time = 5000;
int loop = 0;
//******* MAIN *************************************************************
int main (void){
  initPorts();      // initialize ports
  testing();
  //return 0;        // not needed because of void
//******* TESTING *************************************************************
int testing(void){
  loop = 1;
  while(loop==1){
    counter++;
    //_delay_ms(5000);
    if(counter>=32767){        // prevent overflow
      counter=0;
    else if(counter%2 == 0){    // even
      PORTB = 0x01;
    } else {            // odd
      PORTB = 0x00;
//******* INI *************************************************************
void initPorts(void){
  // definitions I/O
  DDRB = 0xFF;      //  define port B as output
  DDRD = 0x00;      //  define port D as input
  // activate intern pull-up resistors
  PORTD = 0xFC;      //  bites 2 to 7
Author: Sebastian W. (sebastian_w29)
Hello Luk,
if you define F_CPU as 1000UL, then <util/delay.h> assumes that your CPU
would execute only 1000 instructions per second. When calling
_delay_ms(5000) the procedure will therefore return after 5000 CPU
cycles. But as your CPU runs actually much much faster it will thus
return as well much much faster.
You should therefore set F_CPU to the real frequency of your CPU. If
your CPU uses a 16MHz quartz, for instance, you should set F_CPU to
16000000UL. Then _delay_ms(5000) will return only after 5000ms as you
would want it to.
Regarding your program and possible improvements:
The order of header file inclusion is usually not so very important.
There might be exceptions, but I would not know any. However, you should
include only those header files that you also need. For instance, for
your little program above you do not need <stdio.h>.
You can avoid the overflow logic by declaring counter as unsigned int
and letting it overflow deliberately. No harm done later as it smoothly
goes odd 65535 -> even 0.
time should probable be declared as const int, it will then take away no
memory at all. time should also be used.
loop does not need to be global. In fact, loop is completely
superfluous, you can just use while (1) { ...}
You should probably define the pin position of your led in the header of
the program and not in the guts of the testing() procedure. For
instance, const unsigned char LED = 0x01; and then later PORTB = LED;
Have fun, Sebastian
thank you very much =)
Author: chakri chakri (chakri)
hello sir,i am beginner for ATmega8.
i am using AVR studio4 for ATmega8.
while build the program i get a error
kumar.c:3: *** missing separator.  Stop.
Build failed with 1 errors and 0 warnings...
but there is need of separator.
some times it shows at main function.
plz give the solution for my problem.
Author: xmh (Guest)
Hi chakri,
I guess you should remove declaration of internal functions.
