Forum: µC & Digital Electronics Microcontroller for Switch
von Tai Sun (Guest)
Hello all,
I study Informationtechnology about signals and communication.But now I
have to handle a new Project about Microcontroller.
I´d like to design a Switch Module like attachment.Some Inputs in kinds
of CAN,Flexray and BroadR-Reach Ethernet(single pair Ethernet) also
Outputs in other side.It should not be a gateway because the Inputs
signals will be routed to the same kind of Bus.For Example,CAN to
CAN,Flexray to Flexray.
My question is:
1.How many hardware are necessary like Chips,Cables,Transcievers and so
on.
2.which software I can use to make the simulation.
Thank you very much!
von Pete K. (pete77)
First of all, define your requirements and then choose a suited
microcontroller.
With the datasheet of the micro you can find out where to add
peripherals like relais, ethernet, can etc.
Flexray? --- seems to be discontinued since 2010 (Source: Wikipedia)
