Forum: FPGA, VHDL & Verilog Help with VHDL code
von Eddie P. (bertswoot)
I am new to VHDL so I am still very "green".. here is some code for a
4bit 8function simple ALU but first the operations:
F2  F1  F0  Output Function    S0 – S4
0  0  0  Output = A Input       S = A
0  0  1  Output = A Complement  S = NOT A
0  1  0  Output = A Plus B      S = A + B
0  1  1  Output = A Minus B     S = A – B
1  0  0  Output = B Input       S = B
1  0  1  Output = B Complement  S = NOT B
1  1  0  Output = Increment A   S = A + 1
1  1  1  Output = Decrement A   S = A – 1
and since its in INTEGER TYPE im cannot use NOT A or NOT B. My code
compiles fine but since im mew to this how do I get it to work when I
tranfer it to my eSOC board?
 The code:
ENTITY ALU IS
PORT(
  AI      : IN INTEGER RANGE 0 to 15;
  BI      : IN INTEGER RANGE 0 to 15;
  FO      : IN INTEGER RANGE 0 to 7;
  SOUT             : OUT INTEGER RANGE 0 to 31);
END ALU;
ARCHITECTURE FUNCTION8 OF ALU IS
BEGIN
PROCESS (AI,BI,FO)
BEGIN
  IF FO = 000 THEN
    SOUT <= AI;
  ELSIF FO = 001 THEN
    SOUT <=  -AI;
  ELSIF FO = 010 THEN
    SOUT <= AI + BI;
  ELSIF FO = 011 THEN
    SOUT <= AI - BI;
  ELSIF FO = 100 THEN
    SOUT <= BI;
  ELSIF FO = 101 THEN
    SOUT <=  -BI;
  ELSIF FO = 110 THEN
    SOUT <= AI + 1;
  ELSIF FO = 111 THEN
    SOUT <= AI - 1;
END IF;
END PROCESS;
END FUNCTION8;
I guess what Im really asking is do you see anything wrong with the
code?? where did I go wrong?? Any suggestions on some reading material
that will help me better undertsand VHDL would be greatly appreciated..
von lkmiller (Guest)
Did you already do the most easy "hello world!" of hardware: a blinking
led?
That's the point where I start every new platform (CPLD, FPGA, uC).
And after seeing the blinking light I know at least how to handle the IO
pins.
Did you already try to simulate your design?
There's at least one major bug in it: FO has a range to 7, so 010 is out
of range, because 010 is ten. And 011 is eleven...
Thanks for the info. I have sucessfully developed and adder/subtractor..
Doesnt the range also determine how many inputs I have.. Like for the
rules above I used 2^3 to get the number of possible combinations which
is 8.. should I add F0,F1,F2 to the entity as F0 : in integer range 0 to
1;
F1  : in integer range 0 to 1; and so on.. or am I completely off??
von Schlumpf (Guest)
In this case I would use std_logic_vector for F0 to F2 and I would
choose another name than FO for it. Because the risk of confusion about
O or 0 is very high.
e.g.
F      : IN std_logic_vector(2 downto 0);
  IF F = "000" THEN
    SOUT <= AI;
F is an array of bits and not "number" any more..
But if you like to keep integer for F
you have to write:
  IF FO = 0 THEN
    SOUT <= AI;
  ELSIF FO = 1 THEN
    SOUT <=  -AI;
  ELSIF FO = 2 THEN
    SOUT <= AI + BI;
  ELSIF FO = 3 THEN
    SOUT <= AI - BI;
  ELSIF FO = 4 THEN
    SOUT <= BI;
  ELSIF FO = 5 THEN
    SOUT <=  -BI;
  ELSIF FO = 6 THEN
    SOUT <= AI + 1;
  ELSIF FO = 7 THEN
    SOUT <= AI - 1;
You are just freaking awesome!!!!!! thank you so much I went ahead and
used std_logic_vector and it works like a charm.. well everything but
the NOT A and NOT B part which I had as -A and -B for some reason. But
the rest of it worked great.. I cant thank you enough!!!!
never mind it all works great.. you guys are awesome!! thank you for
your time I really do apreciate it!
Well, of course it must be "NOT" instead of "-"... :-)
My fault. I just saw the problem with the F-vector and didn´t care about
the rest :-)
But nice to hear that everything works fine now..
An additional hint:
If you go on coding in VHDL try to think in "Hardware" like "wires",
"registers", "multiplexers",... and try do describe this in VHDL. It´s
not "software" that runs command by command on the target device. VHLD
describes the function and interconnetction of hardware-elements in the
device.
If you try to think this way whilst coding, you will get good synthesis
results and manage the coming obstacles you surely will be faced to if
you go on with VHDL.
von P. K. (pek)
Further more, be careful with "IF..ELSIF..ELSIF.." statements. If just
using "F0" as condition, your synthesizer may come up with a mux as
desired.
However, if you start including other stuff in the "IF" conditions (e.g.
FO =3 and ...), you'll end up in very large number of logic levels.
Therefor: Be on the safe side, use "CASE" statements for such a
situation, which always will end up in a multiplexer.
Thank you for the info.. I really appreciate all the help..
