Forum: FPGA, VHDL & Verilog Interleaver/deinterleaver VHDL
Author: Syed Imam (Company: uni) (si09aad)
Hello,
Can anyone help me out in writting the VHDL code for interleaver and
deinterleaver or if some one can guide me how to write it or its basics.
All i know that i have to declare ROM and RAM's , but how I have no
idea.
Any type of favour or help will be highly appreciated.
Please any one help me out. Your help means alot to me.
THanks
Author: Klaus (Guest)
Please read your post again. And imagine, you were someone else, who
only knows what you have written.
Do you think anyone can give a helpful answer without knowing anything
about what your problem is?
Author: Bolzenfresser (Guest)
I also want interleaver quickly. I also have problems in writing code.
Please help my urgently. Come to my office, analyse my problem and write
code for me, so I can get good marks in school and become good engineer.
Author: berndl (Guest)
here's the code:
toggle_proc: process (clk)
begin
  if rising_edge (clk) then
    interleave_controller_ff <= not interleave_controller_ff;
  end if;
end process;
interleave_proc: process (clk)
begin
    if interleave_controller_ff = '0' then
      output_interleave_controller_1 <= signal_input;
    else
      output_interleave_controller_2 <= signal_input;
    end if;
  end if;
end process;
...and the deinterleaver:
deinterleave_proc: process (clk)
begin
    if interleave_controller_ff = '1' then
      resulting_output_of_interleave_controller <=
        output_interleave_controller_1;
    else
        output_interleave_controller_2;
    end if;
  end if;
end process;
Note: Not yet simulated, but it may give you an idea...
thanks!
Sure somebody can. But:
What do you want to interleave (and subsequntly deinterleave)?
Whats the target platform?
What toolchain do you use?
Where does data come from?
Where does it go to?
What width has the data path?
What speed (bits/s or bytes/s) is desired?
May this be any kind of homework for school?
So indeed you know much more than anybody else here!
Why don't you tell us a little bit more?
For LOTHAR MILLER
I GUESS NOW I HAVE TOLD WHAT IS MY TARGET PLATFORM? WHERE DOES DATA COME
FROM AND WHERE DOES IT GO?
Interleaver (what is basically interleaver)
The main function of the interleaver is to prevent the data information
to be affected by interference which, as shown below in fig(11), results
in burst error in wireless transmission. Indeed, due to the interference
and noise, chunks of data errors can be retrieved in the data streams
after the air transmission. As the burst errors are spread out after the
interleaving process, the detection of errors is easier. Thus more
errors can be corrected; as a result, the Bit Error Rate can be reduced.
Interleaver (why i need ROM and RAM) as I said earlier
The process of interleaving is mainly achieved by the use of RAM 1, RAM
2 1st permutation, and RAM 3. First, the RAM store the data stream in
the same order as it receives them. Then, data are transmitted to the
RAM 2 where they are stored at random address location defined by the
ROM 1st permutation. The ROM 1st permutation is in fact executing the
first permutation by giving the storing address in a manner which
follows the equation of the first permutation defined earlier in the
report.  Finally, the RAM 3 is working in the same way as RAM 2 but
instead of receiving the storing addresses from ROM 1st permutation, it
receives the addresses from ROM 3 which applies the permutation defined
by the second equation of the standard as shown below in fig(2)
MY MAIN TASK IS TO GET THE DATA
lets suppose 1 byte data or any data in form of array
interleaver it and then de-interleaver so that it should recover any
lost data due to noise
any type of help will be highly appreciated
thanks
  • [vhdl]VHDL code[/vhdl]
