1 | ------------------------------------------
2 | ------------------------------------------
3 | -- Date : Sun Jan 13 02:28:08 2013
4 | --
5 | -- Author : Just me
6 | --
7 | -- Company :
8 | --
9 | -- Description : Average reaction time
10 | --
11 | ------------------------------------------
12 | ------------------------------------------
13 | library ieee;
14 | use ieee.std_logic_1164.all;
15 | use ieee.std_logic_arith.all;
16 | use ieee.std_logic_unsigned.all;
17 |
18 | entity Average_reaction_time is
19 | port(
20 | clk: in std_logic;
21 | reset: in std_logic;
22 | stop: in std_logic;
23 | reaction_count: in std_logic_vector (15 downto 0);
24 | reaction_count_average: out std_logic_vector (15 downto 0)
25 | );
26 | end;
27 |
28 | ------------------------------------------
29 | ------------------------------------------
30 | -- Date : Sun Jan 13 02:28:08 2013
31 | --
32 | -- Author : Just me
33 | --
34 | -- Company :
35 | --
36 | -- Description : The average of a sum with 10 products
37 | -- The result will be shown on four 7segment display's
38 | -- with a bcd encoder
39 | --
40 | ------------------------------------------
41 | ------------------------------------------
42 | architecture Behavior of Average_reaction_time is
43 | signal reaction_count0: std_logic_vector (3 downto 0);
44 | signal reaction_count1: std_logic_vector (3 downto 0);
45 | signal reaction_count2: std_logic_vector (3 downto 0);
46 | signal reaction_count3: std_logic_vector (3 downto 0);
47 | signal reaction_count_average0: std_logic_vector (3 downto 0); -
48 | signal reaction_count_average1: std_logic_vector (3 downto 0);
49 | signal reaction_count_average2: std_logic_vector (3 downto 0);
50 | signal reaction_count_average3: std_logic_vector (3 downto 0);
51 | signal count: integer range 0 to 9;
52 | signal sum0: integer range 0 to 90;
53 | signal sum1: integer range 0 to 90;
54 | signal sum2: integer range 0 to 90;
55 | signal sum3: integer range 0 to 90;
56 | signal product0: integer range 0 to 9;
57 | signal product1: integer range 0 to 9;
58 | signal product2: integer range 0 to 9;
59 | signal product3: integer range 0 to 9;
60 | signal average0: integer range 0 to 9;
61 | signal average1: integer range 0 to 9;
62 | signal average2: integer range 0 to 9;
63 | signal average3: integer range 0 to 9;
64 | begin
65 |
66 | --synchronous process
67 | average: process(clk)
68 |
69 | begin
70 | --info: assign the current value of input reaction_count to
71 | -- reactioncount0,1,2,3
72 | reaction_count0 <= reaction_count (3 downto 0);
73 | reaction_count1 <= reaction_count (7 downto 4);
74 | reaction_count2 <= reaction_count (11 downto 8);
75 | reaction_count3 <= reaction_count (15 downto 12);
76 |
77 | --info: convert reaction_count0,1,2,3 to integer wich makes deviding by 10
78 | -- possible
79 | product0 <= conv_integer(reaction_count0);
80 | product1 <= conv_integer(reaction_count1);
81 | product2 <= conv_integer(reaction_count2);
82 | product3 <= conv_integer(reaction_count3);
83 |
84 | --info: if reset pressed set every signal to 0
85 | if (reset = '1') then
86 | reaction_count0 <= "0000";
87 | reaction_count1 <= "0000";
88 | reaction_count2 <= "0000";
89 | reaction_count3 <= "0000";
90 | reaction_count_average0 <= "0000";
91 | reaction_count_average1 <= "0000";
92 | reaction_count_average2 <= "0000";
93 | reaction_count_average3 <= "0000";
94 | count <= 0;
95 | sum0 <= 0;
96 | sum1 <= 0;
97 | sum2 <= 0;
98 | sum3 <= 0;
99 | product0 <= 0;
100 | product1 <= 0;
101 | product2 <= 0;
102 | product3 <= 0;
103 | average0 <= 0;
104 | average1 <= 0;
105 | average2 <= 0;
106 | average3 <= 0;
107 |
108 | elsif (clk'event and clk = '1') then
109 |
110 | --> This is where the issue is: when stop = 1 it keeps adding the product
111 | -- to the sum until stop = 0. I want it to only add one product to the
112 | -- specific sum when stop = 1. I have tried stop = 0 and stop'event but
113 | -- that is not acceptable after a the clk'event. there might be a simple
114 | -- solution but I cant seem to find it. I really appreciate your help.
115 |
116 | if (stop = '1') then
117 | sum0 <= sum0 + product0;
118 | sum1 <= sum1 + product1;
119 | sum2 <= sum2 + product2;
120 | sum3 <= sum3 + product3;
121 | count <= count + 1;
122 | end if;
123 |
124 | if (count = 10) then
125 | average0 <= sum0/10;
126 | average1 <= sum1/10;
127 | average2 <= sum2/10;
128 | average3 <= sum3/10;
129 | count <= 0;
130 | end if;
131 | reaction_count_average0 <= conv_std_logic_vector(average0, 4);
132 | reaction_count_average1 <= conv_std_logic_vector(average1, 4);
133 | reaction_count_average1 <= conv_std_logic_vector(average2, 4);
134 | reaction_count_average1 <= conv_std_logic_vector(average3, 4);
135 | end if;
136 | end process;
137 | reaction_count_average (3 downto 0) <= reaction_count_average0;
138 | reaction_count_average (7 downto 4) <= reaction_count_average1;
139 | reaction_count_average (11 downto 8) <= reaction_count_average2;
140 | reaction_count_average (15 downto 12) <= reaction_count_average3;
141 | end Behavior;
