Forum: FPGA, VHDL & Verilog Daisy-chainable communication
Author: Schnitzgi (Guest)
Hi everyone
For a LED panel project I found myself with the fallowing problem:
-Large amounts of data needs to be distributed to the RGB led's (36bits
per LED, hundrets or even thousands of LEDs).
-Each LED panel has only 64 or 256 leds and I want it to be able to run
in a standalone mode
-A controller (raspberry PI?) feeds the data to the first panel and the
data then runs through all cascaded panel, like in an digital LED strip
So what I am looking for is basically a large shift register that can
hold the data for one full panel (i.e. 64 x 36bits) that can then be
read out (by SPI?) with a simple microcontroller and fed to the LED
controllers. The update rate of the LEDs should be about 60 updates per
second (for smooth animations) which is no problem for a standard
microconroller at 40MHz (I am thinking of using a cortes M0).
The problem is clocking the data through to all the panels. I am looking
at 3-5MBps for bigger cascades. Now it would be pretty simple using a
shift register like structure at 50MHz.
How could this be implemented as cheap as possible? I was thinking FPGA
but that seems to be a little expensive. A CPLD cannot hold that much
data (or can it?).
How to get the data actually into the shift registers is a secondary
problem. There I could make use of a VGA input or even a HDMI input and
run it throug an FPGA since only one controller is needed for this, the
price can be higher.
It is just a project Idea right now and I do not want to start to go
deeper before the basic questions are not answered.
Thanks in advance for any tips or hints.
Author: Schlumpf (Guest)
Maybe you can use a uC with two SPI-Ports.
The Master-Controller makes a big frame containig Data for all LEDs and
starts sending the first byte to the first panel. The panel needs a kind
of configuration (maybe DIP-switch) to know, if the reveiced data is
addressed to that panel. If yes, it makes a copy of each Byte to it´s
memory and sends the byte to the next panel via second SPI.
Master starts sending second byte.....
At the end of the cycle all data for all LEDs have been "seen" by every
panel but because of the configuration each panel has a copy of the data
slice addressed to it in it´s memory.
Alternatively you can choose a controller with ethernet-port.
Then you connect all panels to a switch and each panel receives a
MAC-frame, containig all data for one panel.
Thanks for the input.
It could be doable, but I fear that SPI with overhead of receiving AND
sending (plus crc maybe and addressing bytes) will be too slow. It may
just work if the number of panels is limited to let's say 10 panels but
if I later decide I want more it would not work.
For a small amount of panels I am thinking of using an NRF24 wireless
connection and getting rid of the wiring work. Will do probably just
that for first trials and software tests but later I want higher data
rates.
Another approach I was thinking of was using 8 parallel data lines at
lower speed (8MHz). That also is not feasible on a cortex M0, especially
on the receiving side...
I think you cannot increase the amount of panels to infinitiy because
the amount of data which has to be calculated is getting more and more
an therefore the cycle time increases until you reach a point where the
transmission time is far less then the time the master needs to update
the data.
btw.
As I know, NRF is reduced to a datarate around something like 2 Mbit/s
10 panels x 256 Leds x 36 Bit/LED x 60cycles/s = appx. 5-6MBit/s  :-(
Author: schnitzgi (Guest)
I already did some tests with the NRF24 and it is limited to about
600-700kbps even at 2Mbit transfer rate because of crc and address
overhead.
I do not want to use Ethernet because of cost and wiring effort (sockets
are big, cables expensive and so on).
As mentioned in the initial post, a shift register would do the trick
but cannot hold that amount of data.
I also thougt about using a Propeller uC but for it's 80MHz clock it is
pretty slow because most instructions take 4 clocks and therefore does
not support fast communication.
Think about a display input, that can be full HD with 60 updates per
second no problem by using fast communication ICs.
A DSP with PPI interface would also be an option but that involves a lot
of work in programming for such a "simple" task.
Is there a possibility to do something like the TLC5942 does for 16
channels but for even more channels? I know I could just daisy chain all
of these ICs of each panel but that makes it impossible to have each
panel as a standalone unit and they all only work from one single input.
comments on that?
Well, it seems, that you exactly know what you are doing.
you want to update every 16ms more than 100kBit via serial connetction.
You like to have a solution with almost no cost (shift registers). But
unfortunately there is no 100000 Bit ready to go shift register
available on the market.
You think that a buidling a kind of "shift register" with daisy chained
SPI-Controllers is too slow because they have overhead and CRC (it´s up
to you to build a proper protocol for your application.. you can do it
without a single bit of overhaed)
And you think that 1 Euro for Ethernet Cable and another Euro for the
jack is too expensive.
But you like to do it via nRF which is way to slow and at the end surely
more expensive..
If you want to make it with a shif register you can solder several dozen
shift registers per panel on a pcb and put loads of components around it
to handle emi and clock skews. Or you can impement your own 1000 bit
shift register in an FPGA which needs minimum 2 different power supplies
and at least a 4 layer micro via pcb.
fortunately you get all this for almost no money ;-)
exactly.
I do not want to use LAN cables because I want no star wiring. Imagine a
wall with 10 panels and each one having a power connection to the next
one AND a LAN cable to a hub. thats an awful lot of cables on something
I want to look nice and tidy.
Oh well, maybe I will just go to something more expensive and load each
panel with a WiFi module and a more powerful ARM. Is a huge overkill but
at least it looks the way I want it to.
Star wiring with PoE.... only one cable per panel...
But I´m sure that you also don´t like this idea, because you LIKE to
have it daisy chained ;-)
  • [vhdl]VHDL code[/vhdl]
