Forum: ARM programming with GCC/GNU tools Network printer interfacing with LPC2478
von Swapnil D (Guest)
Hi All,
I'm trying to interface a Printer with the LPC2478, So far I studied few
things,
1. Printer which I have is post script network printer so it required
postscript files as input.
2. I’m able to create simple post script file that can print text and
draw lines.  (Tested with online postscript to pdf conversion utilities
its working fine).
3. I’ve used a EFSL (file system) to store the created post script
files.
4. I’ve used a uIP stack for basic TCP/IP communication and able to run
web server application.
Now problem is I really don’t know how to send the created postscript
file to network post script printer.
What kind of TCP/IP application protocol is required for printer
interfacing (in embedded application)?
Please help me in this if anybody has worked on this kind of
application.
Thanks in advance
Swapnil.
von g457 (Guest)
> interfacing
check out the documentation of your printer. it might use IPP [0].
HF
[0] http://en.wikipedia.org/wiki/Internet_Printing_Protocol
