Forum: ARM programming with GCC/GNU tools confused by various UDP checksum algorithms
von magnetron (Guest)
hello forum,
I am trying to send an UDP packet (contains only "TEST" string)
from STM32 to VB6 winsock
I can see packets going with wireshark software
however winsock data_arrival subroutine never gets called
( if I send from laptop winsock to PC winsock or vice versa  UDP packet
is received OK )
I am suspecting that I cannot calculate UDP checksum correct
in google every single example calculates the UDP checksum different way
my question ,
has anybody a correct algorithm for UDP checksum ?
( which he has tested to be true )
thank you
von (prx) A. K. (prx)
In IPv4, the UDP checksum is optional. If you want to keep things
simple, just set it to zero.
For a working source code: There's plenty of public source code to look
at. Perhaps the most simple (overall) is Adam Dunkels' uip stack for
small µControllers.
I have run uIP demo supplied with the development board already - no
problem
however uIP code is too complex to understand
besides I dont need TCP/IP
I only need send an receive a simple UDP packet to PC
coming to UDP checksum ; I have tried with checksum field zero
no success
von Gruene - Nein Danke (Guest)
Please give a wireshark snapshot
hello thank you,
here is the wireshark printscreen
winsock cannot receive this packet
I have an USRobotics adsl router between PC and STM32F4
Take a look at the first 6 bytes. Thats a broadcast adress.
hello thank you
I tried with the MAC adress of my PC still no success
by the way my original question still open
can you give me a working UDP checksum algorithm
Packets which are invalid at the ethernet level won't arrive at
Wireshark. Also, in my experience, Wireshark complains when it
encounters a bad packet. Since Wireshark does not complain (in the
screen shot shown above), it likely is formally correct at the UDP level
as well.
Since you had a working packet sent via laptop: Is the checksum really
the only difference between those frames? Doing a side by side
comparison.
Concerning the checksum: You told, that you already found several code
snippets for it. Likely most or all of them produce a correct result at
least on the platform they were written for. So getting a few more
slightly different snippets likely won't help a lot.
Anyway, there are authoritative sources: The RFCs for UDP (768) and for
the IP checksum calculation (1071). RFC 1071 even includes sample code.
And BTW: What sources of information did you use for your code? The UDP
checksum isn't simply a checksum of all header and data bytes, but this
should be mentioned in every detailed UDP description.
