Forum: FPGA, VHDL & Verilog pwm modulation/demodulation
von alper y. (alperyazir)
hi everyone. I need help about vhdl code of spartan3e.
i wanna communicate two FBGAs. For example, i am using rotary switch to
produce pwm(it arranges my duty cycles. and i produce my pwm from my 1st
FBGA and use it 2nd FBGA. i tried but it didnt happened.
please help me ??
my codes is:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity rotaryEncoder is
Port (
      clk  : in    STD_LOGIC; -- C9
      RotA : in    STD_LOGIC; -- K18 PULLUP
      RotB : in    STD_LOGIC; -- G18 PULLUP
      data : inout STD_LOGIC_VECTOR(7 DOWNTO 0); -- E12
      leds : inout STD_LOGIC_VECTOR(7 DOWNTO 0);
      sout : inout std_logic;
      sin  : in std_logic);
 end rotaryEncoder;
 architecture rotaryEncoder of rotaryEncoder is
 signal sta       : STD_LOGIC_VECTOR(1 downto 0);
 signal prr       : STD_LOGIC_vector(1 downto 0);
 signal rotary_in : STD_LOGIC_vector(1 downto 0);
 signal RotA1     : STD_LOGIC;
 signal RotB1     : STD_LOGIC;
 signal s1        :std_logic;
 signal s2        :std_logic;
 signal s3        :std_logic;
 signal s4        :std_logic;
 signal s5        :std_logic_vector(3 downto 0);
 signal s6        :std_logic;
 signal s7        :std_logic_vector(1 downto 0);
 signal cmp        :std_logic_vector(3 downto 0);
30
 signal xcount3   : std_logic_vector(7 downto 0);
31
 signal xcount1   : std_logic_vector(8 downto 0);
32
 signal reg       :std_logic_vector(7 downto 0);
33
34
 begin
35
 rotary_filter:
36
 process(clk)
37
  begin
38
    if clk'event and clk='1' then
39
    rotary_in <= RotA & RotB;
40
        case rotary_in is
41
42
          when "00" => RotA1 <= '0';     RotB1 <= RotB1;
43
          when "01" => RotA1 <= RotA1;   RotB1 <= '0';
44
          when "10" => RotA1 <= RotA1;   RotB1 <= '1';
45
          when "11" => RotA1 <= '1';     RotB1 <= RotB1;
46
          when others => RotA1 <= RotA1; RotB1 <= RotB1;
47
        end case;
48
    end if;
49
 end process rotary_filter;
50
51
 direction:
52
  process(clk) is begin
53
      if(rising_edge(clk)) then
54
        case sta & RotA1 & RotB1 is
55
    when "0001" => prr <= "01"; sta <="01"; -- 01 turn right
56
          when "0010" => prr <= "00"; sta <="10"; -- 00 turn left
57
    when "0111" => prr <= "01"; sta <="11"; -- 10 null
58
    when "0100" => prr <= "00"; sta <="00";
59
    when "1000" => prr <= "10"; sta <="00";
60
    when "1011" => prr <= "10"; sta <="11";
61
    when "1110" => prr <= "10"; sta <="10";
62
    when "1101" => prr <= "10"; sta <="01";
63
    when others => null;
64
        end case;
65
          if(prr="00") then
66
            data<=data+1; prr<="10";
67
          elsif(prr="01") then
68
            data<=data-1; prr<="10";
69
          else
70
            null;
71
          end if;
72
       end if;
73
   end process;
74
75
  TRNS:process(clk) is begin
76
77
78
        if(xcount1<="000000000") then
79
        sout<='1';
80
        elsif(xcount1="000000001") then
81
        sout<='1';
82
        elsif(xcount1="000000010") then
83
        sout<='0';
84
        elsif(xcount1="000000011") then
85
        sout<='0';
86
87
        elsif((xcount1<=data)and(xcount1>"000000011")) then
88
            sout<='1';
89
        elsif(xcount1<="100000011") then
90
          sout<='0';
91
        elsif(xcount1="100000011") then
92
        xcount1<="000000000";
93
        end if;
94
    xcount1<= xcount1 + 1;
95
    end if;
96
 end process;
97
98
 RCV:process(clk,sin,s1,s2,s3,s4,s5,s6,s7)is begin
99
100
101
          s1<=sin;
102
         s2<=s1;
103
         s3<=s2;
104
         s4<=s3;
105
          s5<=s1&s2&s3&s4;
106
          s7<=s6&sin;
107
         if(s5="0011") then
108
        s6<='1';
109
        end if;
110
        if(s7="11") then
111
112
            leds<=leds;
113
            reg<=xcount3;
114
        else
115
            leds<=reg-3;
116
        end if;
117
        xcount3<= xcount3 + 1;
118
119
        if(xcount3="11111111") then
120
          xcount3<="00000000";
121
        end if;
122
         if(reg="11111111") then
123
         reg<="00000000";
124
         end if;
125
      end if;
126
    end process;
127
 end rotaryEncoder;
Did you simulate your design? How does the testbench look like? And:
what's the problem at all? What does not "happen"? What do you expect?
And what do you get?
von Manni (Guest)
I am again surprised, how complex a AB-decoding can be done. I never
learned about that and therefor was very new to it, when I had to do it
the first time. What I am doing:
I sample the incoming value with a frequency which is low enough, that
bouncing has no effect anymore and decide, if the value changed. When it
inreased or had an overrun, I am adding 1 to my result, in the other
case i substracted one. Allways worked sufficiently.
