Forum: µC & Digital Electronics Converting an ieee number
von Jake (Guest)
I'm trying to write an ARM program that will convert an ieee number to a
TNS format number. TNS is a format used by some super computers, and is
similar to ieee but different. I'm trying to use several masks to place
the three different "part" of the ieee number in separate registers so I
can move them around accordingly. Here is my unpack subroutine:
UnpackIEEE
    LDR r1, SMASK   ;load the sign bit mask into r1
    LDR r2, EMASK   ;load the exponent mask into r2
    LDR r3, GMASK   ;load the significand mask into r3
    AND r4, r0, r1  ;apply sign mask to IEEE and save into r4
    AND r5, r0, r2  ;apply exponent mask to IEEE and save into r5
    AND r6, r0, r3  ;apply significand mask to IEEE and save into r6
    MOV     pc, r14     ;return
And here are the masks and number declarations so you can understand:
IEEE        DCD 0x40300000  ;2.75 decimal or 01000000001100000000000000000000 binary
SMASK       DCD 0x80000000  ;Sign bit mask
EMASK       DCD 0x7F800000  ;Exponent mask
GMASK       DCD 0x007FFFFF  ;Significand mask
When I step through with the debugger, the results I get are not what I
expect after working through it on paper. EDIT: What I mean, is that
after the subroutine runs, registers 4, 5, and 6 all remain 0. I can't
figure out why the masks are not working. I think I do not fully
understand how the number is being stored in the register or using the
masks wrong. Any help appreciated. If you need more info just ask.
: Moved by Admin
