Forum: ARM programming with GCC/GNU tools STM32L1xxx µC displaying memory contents
von vinay k. (Company: Student) (kumar23986)
Hi All!
I am very new to this forum and first of all would like to greet
everyone from my side. I am working as an intern and working with
STM32L152 EVAL board. I am supposed to take the digital values from the
ADC converter from an analog input and save them for the first run. In
the second run I have to save the second values and compare both of
them. Actually I have initialised an array and stored the converted
values in them. But it is not required to take all the converted values,
so I tried to write the program in such a way so that I take the
converted values only from the peaks of the curves. But, the problem is
when I give &ADCdata[0] and &B[0](the reduced array)as inputs in the
"Adress" tab, I am getting the same values for both the arrays. the B[]
array has one element less than the ADCdata[] array.
Where do u think is the problem. Any suggestions would be of great help.
I am struggling on this since 3 weeks now. And I also have to save these
array values and compare them with the future values.
Thankyou!
Kumar
von layin (Guest)
I came to the conclusion that the problem obviously is in
your code, which you failed to show.
You probably should consider getting another job.
von Kumar (Guest)
Hi, I have attached a pdf document with the program I wrote.
Any Help would be appreciated!
Thankyou!
von Jim M. (turboj)
Why pdf? This forum has direct support for C code files with syntax
highlighting. Your PDF is hard to read, don't expect much help here.
