Forum: FPGA, VHDL & Verilog Testbench of d flip flop
Author: Fahim Khan (fahimk)
I am trying to run vhdl code of d flip flop on ghdl.
I am not getting any error while compiling and executing,however when I
try to run it, it doesnt come to prompt again it keeps on runing.
Please let me know where I am making mistake.
My code is as below.
library ieee ;
use ieee.std_logic_1164.all;
entity dff is
port ( din:     in std_logic;
       dclk:     in std_logic;
       qout:    out std_logic;
       nqout:   out std_logic
end dff;
architecture behavioral of dff is
begin
        process(din,dclk)
        begin
          --- clock rising edge
        if(dclk='1' and dclk'event) then
                qout <= din;
                nqout <= not din;
        end if;
        end process;
end behavioral;
------TestBench of D Flip Flop------------
library ieee;
entity dff_tb is
end dff_tb;
architecture testbench of dff_tb is
        signal T_din:   std_logic;
        signal T_dclk:  std_logic;
        signal T_qout:  std_logic;
        signal T_nqout: std_logic;
        constant clk_period : time := 50 ns;
        component dff
               dclk:    in std_logic;
        end component;
begin
    dut_dff: dff port map (T_din,T_dclk,T_qout,T_nqout);
    process
        begin
          T_dclk <= '0';
          wait for clk_period/2;
          T_dclk <= '1';
    end process;
    process
        begin
          --case1
          T_din <= '0';
          wait for clk_period*2;
          --case2
          T_din <= '1';
          wait for clk_period*1.5;
          --case3
          T_din <= '0';
          wait for clk_period*0.5;
          --case4
          T_din <= '1';
        wait;
   end process;
end testbench;
Author: P. K. (pek)
You have to stop the testbench somehow at the end, e.g. by an assertion
like:
    assert false
      report " ===== Verification run 'TESTBENCH' finished ====="
      severity failure;
Otherwise, your clock process will run forever...
> it keeps on runing.
Which toolchain do you use?
Usually there's also a button "run for a specified time". There you can
say: run my simulation for 100ns, then stop.
BTW:
Don't use positional assignment. I promise you: you will run into
problems with this after the first minor change. Where's the problem
here:
     dut_dff: dff port map (T_din,T_dclk,T_nqout,T_qout);
Write it with explicit assignments, and then you can twist and move
every port:
dut_dff: dff port map (qout=>T_qout,din=>T_din,dclk=>T_dclk,nqout=>T_nqout);
I changed the code to use assert statement but still getting same issue.
library ieee ;
entity dff is
       dclk:     in std_logic;
end dff;
begin
  process(din,dclk)
  begin
    qout <= din;
    nqout <= not din;
  end if;
  end process;
end behavioral;
library ieee;
entity dff_tb is
end dff_tb;
  component dff
         dclk:  in std_logic;
  end component;
begin
    process
  begin
    T_dclk <= '0';
    wait for 5 ns;
    T_dclk <= '1';
    wait for 5 ns;
    end process;
    process
  variable err_cnt: integer := 0;
  begin
    --case1
   T_din <= '1';
  wait for 12 ns;
  assert (T_qout='1') report "Error1!" severity error;
  if (T_qout/='1') then
      err_cnt := err_cnt + 1;
  end if;
  -- case 2
  T_din <=  '0';
  wait for 28 ns;
  assert (T_qout='0') report "Error2!" severity error;
  if (T_qout/='0') then
  end if;
  -- case 3
  T_din <= '1';
  wait for 2 ns;
  assert (T_qout='0') report "Error3!" severity error;
  end if;
  -- case 4
  T_din <= '0';
  wait for 10 ns;
  assert (T_qout='0') report "Error4!" severity error;
  end if;
  -- case 5
  T_din <=  '1';
  wait for 20 ns;
  assert (T_qout='1') report "Error5!" severity error;
  end if;
  -- summary of all the tests
  if (err_cnt=0) then
      assert false
      report "Testbench of Adder completed successfully!"
      severity note;
  else
      assert true
      report "Something wrong, try again"
      severity error;
  end if;
  wait;
   end process;
end testbench;
I am using ghdl.
Got it I am stoping it after 500ns using
ghdl -r dff_tb --stop-time=500ns
Author: P. K. (pek)
Fahim Khan wrote:
>   if (err_cnt=0) then
>       assert false
>       severity note;
>   else
>       assert true
>       severity error;
>   end if;
Wrong, needs to be:
   if (err_cnt=0) then
       assert false
       severity failure;
   else
       assert false
       severity failure;
   end if;
The assert condition has always to be "false", if you want it to trig...
...then it will work as expected. And to be sure it stops, use severity
"failure", this is usually a break condition by default.
Author: berndl (Guest)
With GHDL and other simulators (e.g. ModelSim) I usually have in my TB:
   clk_process : process
   begin
    wait for clk_period*5;
    loop
      clk50 <= '1';
      clk50 <= '0';
      exit when end_of_sim = '1';
    end loop;
    wait;
   end process;
...this (or something similar) for all special processes I have in the
TB...
And in my 'main' TB execution process (snippet of the end of this
process):
    --assert end_of_sim = '1'
    --  report "---- End of module simulation reached ----" severity note;
    end_of_sim <= '1';
    wait;
   end process;
This will stop GHDL and others, either with the 'assert' (commented out
here) or 'automagically'... (of course, 'end_of_sim'
initially/previously set to '0')
  • [vhdl]VHDL code[/vhdl]
