I'm trying to make my Stratix II (EP2S60F1020C4) communicate with the Miniceptor (WJ-8607A) through RS-232. I am able to communicate with the Miniceptor from the computer using Hyper Terminal without a problem, communication between the FPGA and the computer is absolutely fine, but the FPGA and the Miniceptor cannot communicate properly between themselves. I have tried to send commands from the FPGA to the computer, and I receive exactly what I am supposed to. I've also send words directly from the computer to the Miniceptor and the chip receives commands without fault. But when I send the same words from the FPGA directly to the Miniceptor, the Miniceptor does not recognize the sent commands. I've already made sure the voltage levels of the signals match specifications on both sides, and I've analyzed the sent words using a logic analyzer. Everything appears to be in order, I'm sending what I should be, but the Miniceptor just won't recognize it. Any suggestions! Time is of the essence, any help is appreciated. Thanks!!
Is your problem resolved? If not, could you give some description of top module, it may help others to guess problems
Dean Dean wrote: > I've already made sure the voltage levels of the signals match > specifications on both sides, and I've analyzed the sent words using a > logic analyzer. Can you post pictures of a transmission (e.g. of the bytes 0x55 and 0xAA)?
