Forum: FPGA, VHDL & Verilog Error: Not enough of logic cells.
Author: Daisy-Cat (Guest)
Hey, guys!
I work with the Quartus II (VHDL) and I see this error: "Error: Design
contains 6912 blocks of type logic cell.  However, device contains only
2910."
And, if I remove the line "count_out: = count;" of the first process,
the program is only 474 cells.
You guys are my last hope! Help :*
This is the code:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
entity counter_controller is
  port (
    clk          : in   std_logic;
    info      : in   std_logic_vector(0 to 2);
    counter_in    : in   std_logic;
    counter_out    : out  std_logic_vector(9 downto 0)
end counter_controller;
architecture Behavioral of counter_controller is
  shared variable count_out  : unsigned(9 downto 0)   := (others => '0');
  signal count    : unsigned(9 downto 0)   := (others => '0');
  signal rst       : std_logic := '0';
begin
  counter_out <= std_logic_vector(count_out);
  process(counter_in, rst)
  begin
    if(rst = '1') then
      count_out := count;
      count <= (others => '0');
    elsif(rising_edge(counter_in)) then
      count <= count + 1;
    end if;
  end process;
  process(clk)
    variable waiting  : natural         := 0;
    variable sec    : unsigned(5 downto 0)  := (others => '0');
  begin
    if rising_edge(clk) then
      if waiting >= 40000000 then
        if info(1) = '0' then
          rst <= '1';
          waiting := 0;
          sec := (others => '0');
        else
          if sec >= 45 then
            rst <= '1';
            waiting := 0;
          else
            rst <= '0';
            sec := sec + 1;
          end if;
        end if;
      else
        rst <= '0';
        waiting := waiting + 1;
      end if;
    end if;
  end process;
end Behavioral;
Author: OhhNo (Guest)
Wow, I have never seen such a strange description of a counter. Is it
youre first FPGA design? I think you should beginning with some basics.
http://www.lothar-miller.de/s9y/categories/1-VHDL
In this stupidly simple design i would expect to get around 50 flipflops
and a little bit glue logic. So all far, far away from your numbers!
Why the heck do you need a shared variable?
The first half year of your VHDL career you will not need ANY
variables at all!
  begin
    if(rst = '1') then
      count_out := count;
What should this do?
The sensitivity list is incomplete, because a change of count leads to
a change of count_out and therefore must lead to a recalculation of
this process.
And because of the list being incomplete your simulation is wrong.
  begin
    if(rst = '1') then
      count_out := count;
      -- do nothing with count_out
    end if;
  end process;
Also this is a hidden latch on count_out. And thats a major mistake,
because for sure you do not need or even want a latch in this design.
As far as i see, you want to build a kind of a frequency or cycle
counter (how much cycles of counter_in in a certain time)?
How fast is or which frequency has counter_in?
I assume clk has 40MHz.
Then you count 1sec PLUS 25ns there:
Sorry, guys, but I'm just learning.
My task is to implement a count of pulses number from the input
"counter_in" per second or per 45 seconds (depending on the input
"info(1)").
As you have correctly understood, clk has 40MHz. Frequency from the
input "counter_in" 5-50 Hz.
I decided to write here, because a week can `t deal with this error. I
tried to rewrite the code a few times ...
Thanks for your response!
And, so.. Even this realization causes this error:
  signal count_out  : unsigned(9 downto 0)   := (others => '0');
begin
  rst <= info(0);
  process(counter_in, rst, count)
  begin
    if(rst = '1') then
    count_out <= count;
    count <= count + 1;
    end if;
  end process;
end Behavioral;
where "info(0)" - switch.
Which one?
> Frequency from the input "counter_in" 5-50 Hz.
Ok, so thats indeed not really a clock signal, but a slow input signal.
(A beginners design must have only one clock, and thats the one from
the crystal, here 40MHz)
Now lets try it the new information in a new fashion:
library IEEE;
  port (
    clk           : in   std_logic;
  signal c_in_sr    : std_logic_vector(2 downto 0) := "000"; -- shift register for sync and edge detect
  signal c          : integer range 0 to 50*45 := 0;         -- the counter: 45sec with max. 50Hz
  signal onesec     : integer range 0 to 40000000-1 := 0;
  signal sec        : integer range 0 to 45-1       := 0;
begin
  c_in_sr <= c_in_sr(1 downto 0) & counter_in when rising_edge(clk); -- syncchronize the input signal
  process begin
    wait until rising_edge(clk);
    if (c_in_sr(2 downto 1) = "01") then -- detect rising edge of input signal
       c <= c+1;                         -- and count the rising edges
    end if;
    if (onesec < 40000000-1) then  -- count for one second
      onesec <= onesec+1;
    else
      onesec <= 0;
      if (info(1) = '0') then     -- sample counter every second
        counter_out <= std_logic_vector(to_unsigned(c,10));
        c     <= 0;
        sec   <= 0;
      else                        -- sample counter every 45 seconds
        if (sec < 45-1) then      -- count 45 seconds
          sec <= sec+1;
        else
          c     <= 0;
          sec   <= 0;
        end if;
      end if;
    end if;
  end process;
end Behavioral;
Oh, this code produces the same error :(
I don't understand what the problem is.
By the way, I use the Quartus and Cyclone FPGA.
I have no experience with Quartus, but with Xilinx ISE i get:
Number of Slices 37
Number of Slice Flip Flops 54  (a few posts above i expected 50)
Number of 4 input LUTs 61
And thats a fairly small design.
I assume there is something wrong in the project settings in your
design.
Author: Michael F. (michael_f53)
I ran Lothars code through QuartusII 12.1 for a CycloneIV.
I get a Resource Utilization for the counter_controller entity of 69
Logic Cells and 43 LUT/Register LCs.
Seems fine for me.
Dasiy-Cat, did you try Lothars code?
  • [vhdl]VHDL code[/vhdl]
