Forum: FPGA, VHDL & Verilog Multi-source
Author: eduardo melara (edumelara)
Hello.
I am trying to make a mac component. Everything is fine, until I put
reg_acc (my accumulator) receiving the output value.
The strange thing is that Quartus sythetize it, but Modelsim acuse a
multi-source and responde with X in output value.
Do you guys have any ideas?
Here is the code:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
ENTITY main IS
generic (
size : integer := 4;
port (
clk : in std_logic;
rst : in std_logic;
a_i : in std_logic_vector(size-1 downto 0);
b_i : in std_logic_vector(size-1 downto 0);
out_o : out std_logic_vector(2*size-1 downto 0)
END main;
ARCHITECTURE bhv OF main IS
COMPONENT mac
generic (
width : integer);
port (
clk : in std_logic;
rst : in std_logic;
a_i : in std_logic_vector(width-1 downto 0);
b_i : in std_logic_vector(width-1 downto 0);
acc : in std_logic_vector(2*width-1 downto 0);
out_sig : out std_logic_vector(2*width-1 downto 0)
END COMPONENT;
signal acc, out_sig, out_acc : std_logic_vector(2*size-1 downto 0) := (others => '0');
BEGIN
mac1: mac GENERIC MAP (size) PORT MAP (clk, rst, a_i, b_i, acc, out_sig);
reg_out : process(clk, rst)
begin
if rst = '1' then
out_o <= (others => '0');
elsif clk'event and clk = '1' then
out_o <= out_sig;
end if;
end process;
reg_acc : process(clk, rst)  ---> HERE IS THE TROUBLE
begin
if rst = '1' then
acc <= (others => '0');
acc <= out_sig;
end if;
end process;
END bhv;
Author: guest (Guest)
maybe it´s a problem that the two processes reg_out and reg_acc do the
same, just the names of the signals the values are assigned to are
different (out_o vs. acc). So maybe the result is ONE net with TWO Names
and this causes Modelsim to respond with a multi-source error.
But then I don´t know why Quartus synthesizes it (are there warnings?).
Did you take a look at the synthesized circuit?
I attached a screenshot of quartus ciruit.
No ideas?
What does the testbench look like? And which signal goes X? Is there an
assignment on the output signal?
Take a look.
Author: P. K. (pek)
You assign "out_sig" to "out_o". Check, whether "out_sig" is properly
assigned a value to (within "mac"), as there are X'es from the start of
the simulation...
Author: bko (Guest)
There is another Eduardo, he got this recommendation:
>3) Don't use positional assignments. Use the named assignment! Makes you
>code much more readable.
Just follow this advice, then you will see your mistake..
Startpoint:
     mac1: mac
            GENERIC MAP (width => size)
            PORT MAP (clk => clk,
                      rst => rst,
                      a_i => a_i,
Thanks for the answers!
  • [vhdl]VHDL code[/vhdl]
