Forum: FPGA, VHDL & Verilog Generic component inside generic component
von Eduardo (Guest)
Hello.
I am designing a vhdl code that has a generic size setting a bunch of
operations.
I cannot synthetize it with quartus (Error (10346): VHDL error at
mac.vhd(7): formal port or parameter "width" must have actual or default
value), but I am able to compile with modelsim.
My question is, can I put a generic component inside another? If dont,
how should I proceed?
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
use ieee.numeric_std.all;
ENTITY main IS
  generic (
    size : integer := 4);
  port (
    clk     : in  std_logic;
    rst     : in  std_logic;
    a_i     : in  std_logic_vector(size-1 downto 0);
    b_i     : in  std_logic_vector(size-1 downto 0);
    out_o    : out std_logic_vector(2*size-1 downto 0)
END main;
ARCHITECTURE bhv OF main IS
  COMPONENT mac
  generic (
    width : integer);
  port (
    clk     : in  std_logic;
    rst     : in  std_logic;
    a_i     : in  std_logic_vector(width-1 downto 0);
    b_i     : in  std_logic_vector(width-1 downto 0);
    acc   : in  std_logic_vector(2*width-1 downto 0);
30
    out_o    : out std_logic_vector(2*width-1 downto 0)
31
32
   END COMPONENT;
33
34
  signal acc  : std_logic_vector(2*size-1 downto 0) := (others => '0');
35
36
37
BEGIN
38
39
      mac1: mac GENERIC MAP (size) PORT MAP (clk, rst, a_i, b_i, acc, out_o);
40
41
  END bhv;
42
43
library ieee;
44
45
46
47
48
49
ENTITY mac IS
50
  generic (
51
    width : integer);
52
  port (
53
    clk     : in  std_logic;
54
    rst     : in  std_logic;
55
56
57
58
59
60
END mac;
61
62
63
ARCHITECTURE bhv OF mac IS
64
  COMPONENT mul
65
   generic (
66
      W_g     : integer);
67
    port (
68
      clk      : in  std_logic;
69
      rst      : in  std_logic;
70
      a_i      : in  std_logic_vector(W_g-1 downto 0);
71
      b_i     : in  std_logic_vector(W_g-1 downto 0);
72
      outm_o   : out std_logic_vector(2*W_g-1 downto 0)
73
74
   END COMPONENT;
75
76
  COMPONENT soma
77
   generic (
78
      W_gs : integer);
79
    port (
80
      clk      : in  std_logic;
81
      rst      : in  std_logic;
82
      outm_o   : in  std_logic_vector(2*W_gs-1 downto 0);
83
      acc     : in  std_logic_vector(2*W_gs-1 downto 0);
84
      outs_o   : out std_logic_vector(2*W_gs-1 downto 0)
85
86
   END COMPONENT;
87
88
  signal outm_o, outs_o   : std_logic_vector (2*width-1 downto 0) := (OTHERS => '0');
89
90
91
BEGIN
92
      mul1: mul GENERIC MAP (width) PORT MAP (clk, rst, a_i, b_i, outm_o);
93
      soma1: soma GENERIC MAP (width) PORT MAP (clk, rst, outm_o, acc, outs_o);
94
    out_o <= outs_o;
95
  END bhv;
von Klaus (Guest)
1) Only use libraries you really need! In your case this is only the
first one
2) Don't use ieee.std_logic_arith and ieee.std_logic_unsigned at all
3) Don't use positional assignments. Use the named assignment! Makes you
code much more readable.
4) Show us to which line your error message exactly belongs!
von Eduardo (Guest)
Un, ok.
What do you mean by "3) Don't use positional assignments. Use the named
assignment! Makes you code much more readable."
Quartus points to this generic value:
ENTITY mac IS
  generic (
    width : integer);
  port (
    clk     : in  std_logic;
    rst     : in  std_logic;
END mac;
von Klaus (Guest)
I mean the following syntax:
      mac1: mac
            GENERIC MAP (width => size)
            PORT MAP (clk => clk,
                      rst => rst,
                      a_i => a_i,
                      b_i => b_i,
                      acc => acc,
                      out_o => out_o);
So the order of assignments in the generic and port map is unimportant,
because it is described explicit, which signal is connected to which
port. But that's not the origin of your error message. Just a general
advice ;-)
> first one
I'm sorry. I did't see the integer generic. So you need
ieee.std_logic_1164 and ieee.numeric_std
Regarding your error message: In general it is no problem, to use a
generic value like this. Maybe Quartus has a problem with generics on
top level entities? This is just a guess. Because the code look ok for
me.
von Eduardo (Guest)
Thanks for the advice.
I am out of ideas to fix this =[
von Eduardo (Guest)
Got it!!!
Just had to set main vhdl file as top level entity!
But thanks for those hints =D
