Forum: ARM programming with GCC/GNU tools "undefined reference to memcpy" error - please help!
von magnetron (Guest)
hello dear forum ,
I am trying to compile a C program for STM32F407 microcontroller
with OlimexODS  ( Eclipse + yagarto compiler )
I get the error;
as you can see in the attached picture
---------------------- makefile ------------
CROSS_COMPILE = arm-none-eabi-
CC = $(CROSS_COMPILE)gcc
SIZE = $(CROSS_COMPILE)size
STRIP = $(CROSS_COMPILE)strip
OBJCOPY = $(CROSS_COMPILE)objcopy
OBJDUMP = $(CROSS_COMPILE)objdump
LD = $(CROSS_COMPILE)ld
AS = $(CROSS_COMPILE)as
# Flags
CFLAGS = -Wall -fno-common -c -g -mcpu=cortex-m3 -mthumb
CFLAGS += -g $(OPTIMIZATION) $(INCLUDES) -DTRACE_LEVEL=$(TRACE_LEVEL)
ASFLAGS = -g -mapcs-32
LDFLAGS = -g -v -nostartfiles
OBJCOPYFLAGS = -O binary
OBJDUMPFLAGS = -x --syms -S
why the linker cannot find a libray function
which is 40 years old already ?
von teo (Guest)
please post the c-code
von guest (Guest)
Why? This is a linker error.
von Fred S. (Guest)
Did you include string.h or memory.h?
I am not familiar with your IDE, but memcpy() usually requires one of
these include files.
hello
as you can see in the attachment
if I include any of standart library header files
it gives "unresolved inclusion" error
besides the original "undefined reference" error is still there
if I build again
von Walleby (Guest)
Hey,
im using the same IDE with YAGARTO-Toolchain. I had the same problems
few days ago.
Do you have this 4 path in your project? Otherwise the compiler wont
find your included files.
von Walleby (Guest)
Ahh... Sry for double pictures...
von Oliver (Guest)
Well, simply not putting it in is probably not the right solution.
All these effects point into the direction of a incomplete or defect
installation of the tool chain. Apparently the compiler is missing the
system include dir paths, and the linker is missing the system lib path.
Oliver
von Johann (Guest)
Is there a specific reason why you call target-ld by hand and don't use
the driver target-gcc for linking?
If you call it by hand you will have to set all the options by hand that
the driver would set for you...
I totally agree
however this IDE I downloaded from Olimex
the name of this package is OlimexODS
the package sucessfully installed
only I had to install Java seperately
and I had to adjust the PATH variable of my windows XP
to point to ...yagarto\bin
von Franky (Guest)
Would all of you PLEASE stop talking all your include file nonsense?
This is a linker error, include files have NOTHING to do with it. The
linker doesn't find thee libraries. Libraries, not headers!
von Johann L. (gjlayde)
As I already said, the problem is that you call the linker with the
wrong options.  Use the driver for linking, not a naked ld, i.e. instead
of.
you want
LD = $(CROSS_COMPILE)gcc
AS = $(CROSS_COMPILE)gcc
For example, -nostartfiles makes no sense as an ld flag because ld knows
nothing at all about start files.  -nostartfiles is a flag for the
driver, i.e. for $(CROSS_COMPILE)gcc.
>Author: Johann L.
hello I took your advice
however this time it gives error about map file
c:/olimexods/yagarto/bin/../lib/gcc/arm-none-eabi/4.5.1/../../../../arm-none-eabi/bin/ld.exe:./main.map: file format not recognized; treating as linker script
c:/olimexods/yagarto/bin/../lib/gcc/arm-none-eabi/4.5.1/../../../../arm-none-eabi/bin/ld.exe:./main.map:2: syntax error
make: *** [main.out] Error 1
if I comment this out in linker command line
>-Map main.map
it compiles
I have some questions ;
1) is this map file important ?
2) if I link with gcc instead of ld , will the code be stable ?
will it link with latest version of library ?
thanks
magnetron wrote:
>>Author: Johann L.
> syntax error
>>-Map main.map
> it compiles
It's important to find out what goes wrong. It's a dump file and
won't change the compilation result, just like temporary files like
-save-temps.
Is it stable not?  Add -v to the gcc command line and observe the
linker command it issues.  Prosumably, the command line generated by
gcc is much closer to a correct one tha a comman line you write by hand.
Calling the ld by hand instead of by means of the driver (gcc) is the
most common reason for problems with the linker.
I don't know your library. And Idon't know STM or ARM.
It's just the general scheme how gcc works. If GCC and Binutils and the
libraries are configured and built correctly, it will work.
von Oliver (Guest)
Your trials with using ld directly did not produce any usable code at
all.
The program "gcc" itself is neither a compiler nor a linker. It is the
standard interface to all elements of the tool chain (compiler, linker,
assembler, ...), and calls all of them, using the right paprameters.
Therefore using gcc is the most appropriate option.
Oliver
c:/olimexods/yagarto/bin/../lib/gcc/arm-none-eabi/4.5.1/../../../../arm-none-eabi/lib\libg.a(lib_a-sbrkr.o): In function `_sbrk_r':
C:\msys\1.0\home\yagarto\newlib-build\arm-none-eabi\newlib\libc\reent/../../../../../newlib-1.18.0/newlib/libc/reent/sbrkr.c:60: undefined reference to `_sbrk'
hello forum,
I squeezed the error down to above message after I changed the
...ld to ...gcc
I searched the forum for past messages
some people faced the same error like me
but I didnot understand anything
what is this _sbrk?
how can I get rid of it ?
thanks
_sbrk is used to get memory from the OS, e.g. during malloc.
Thus, _sbrk is typically supplied by your OS or libgloss or similar.
hello thanks for the answer but
I have no operating system
this is a standalone application
on an ARM Cortex M4 microcontroller
thank you, how can I proceed ?
Use an OS, implement _sbrk, don't use malloc et al. or implement your
own malloc et al.
Most likely you don't really want malloc.
von Oliver (Guest)
or read the documentation of newlib. google will give you also some more
info on that issue.
Oliver
