Forum: FPGA, VHDL & Verilog Starter board : Digilent Digilab XLA FPGA Development Board XLA3
von Mem M. (Company: none) (memmakersorg)
I've been advised to start with a small projects such as blinking LED, 7
segment LED, etc.
Would this board do the trick:
  I use a Mac or Linux for development ... don't have a windows machine
for background.
Thanks.
The mentioned board is a VERY ancient one. So you cannot use the current
toolchain, and you have to change to one out of the last millenium.
Also this board doesn't have an onboard configuration memory and so you
must always load your design after power up from the PC.
My advice: go for a Spartan 3 board. Then you can use the Linux version
of the ISE tools.
von Josh (Guest)
Try OK6410-H from arm9board.net,
http://www.arm9board.net/sel/prddetail.aspx?id=348&pid=200.
Very nice ARM11 board for starters, coming with complete source code,
toolchains, documentations, example programs, tutorials and great tech
support.
